CC rear power door locks - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-14-2014, 01:52 PM Thread Starter
I have a 97 XLT CCLB. When I got it I was aware of wiring harness damage where the harness goes from the body to the rear doors. this was causing issues with the power windows and, I thought, the power door locks. I went to repair that today and discovered that this truck doesn't power door locks (or at least the actuator was missing from the side that I pulled a door panel off of).
The lock knobs are chrome things with the bulb so you can grab them to manually unlock, and there is no lock/unlock switch in the door panel. I assumed that the prior owner had swapped in the chrome knobs when the power locks stopped working. It didn't occur to me until today that there were no switches...
Has anyone ever seen a crew cab with power locks up front but not in the back? Looked like the wiring was there, can I just get actuators and add the to the existing hardware, or are the latch mechanisms different?
Thanks for any light anyone can shed on this, I am confused.
'97 F350 CCLB XLT 4x4,6637 air filter, 3" DP to 4" exhaust, hypermax intercooler, EBPV wired as exhaust brake.
highcountry87 is offline
post #2 of 10 Old 06-14-2014, 02:38 PM
Quoted: 5 Post(s)
there are no door lock switches in the back, only on the front.
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #3 of 10 Old 06-14-2014, 02:42 PM Thread Starter
That is interesting, even on trucks with power rear locks? Where the original lock knobs the smooth black ones? Seems like the rear passengers would be locked in if that were the case.
post #4 of 10 Old 06-14-2014, 07:17 PM
Quoted: 5 Post(s)
Yes. My 95 CC has power locks, and no it does not have any switches. The black "anti theft" knobs stick up enough to pull on to unlock. The fronts should sit level with the door panel, to prevent unlocking via the vent windows.
As long as the U shaped brackets are still there, replacement actuators aren't terribly expensive. However, if the bracket is broken or missing, you'll have to fab something up, as I've never seen them for sale anywhere. And Ive looked, ALOT.
ianstew is offline
post #5 of 10 Old 06-14-2014, 08:45 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I've never seen a truck with door lock switches in the back PERIOD..... Especially an obs, and I've had a 97 and still drive a 95, and my 01 doesn't have switches in the rear either
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 10 Old 06-15-2014, 06:10 AM Thread Starter
Huh, this is my first crew cab, you learn something new every day! Thanks for the help. I guess I will pull the door panels again to see what parts I am missing. It would be really nice to have power locks all the way around, and it sounds like the lack of power locks in the back is a bit of a mystery still.
post #7 of 10 Old 06-15-2014, 06:16 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
In the 94.5 and down they never had power rear locks it's a 95+ only, which is odd since you have a 97
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 10 Old 06-15-2014, 06:34 AM
Patrick Feeley's Avatar
Quoted: 17 Post(s)
My 94 had both power locks and power windows. None of them had power lock switches in the rear doors. You don't want the little munchkins in the rear playing with the locks for safety reasons. On mine, when an actuator went out, I used a factory unit I found on ebay for $10. It was for some other Ford vehicle, so all I did was swap the actuator rod off my old one. My bracket was still good but possibly other vehicles may use the same one? Cheers!
Patrick Feeley is offline
post #9 of 10 Old 06-15-2014, 04:27 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
Good luck finding actuators(actually the rod on the actuator).
Last i check the actuator WITH the rod was about $300
The rod is Specific to these crew cab rear doors. But the actuator ford used forever in multiple vehicles
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #10 of 10 Old 06-17-2014, 10:03 PM Thread Starter
Fantastic news, I pulled the rear door panels again, and low and behold, the actuators were there, but were unplugged and mechanically disconnected from the latch assembly (I was looking in the wrong place, duh). I plugged them in, hooked them up to the latches, and boom, power door locks. My guess is that the locks were blowing a fuse when hooked up because of the wiring harness damage, so someone disconnected them. Can't think of any other reasons why someone would have done that...
Thanks for all your help guys!
