Rke Harness Swap - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-30-2014, 08:10 AM Thread Starter
cthom388's Avatar
Rke Harness Swap
Ok so i recently got a parts truck and it is a 1996 2wd Super Cab Dually 7.3 xlt Automatic truck. My truck is a 4wd 5 speed xl. What i am wondering is the parts truck has factory rke in it, so could i just replace my dash with the one out of that truck and plug all of the harnesses right up? I noticed a module behind the glovebox that said for dual wheel only. Will my truck have that module i could just plug in in its place? I guess to sum it up will it be plug and play?
1995 F250 4X4 Zf5
  • TS 6 POS Power-Struck Tunes
  • 3" Silverline Dp to Straight Pipe
  • Custom E-Fuel/Regulated Return
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
post #2 of 6 Old 04-30-2014, 12:30 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Aside from the automatic stuff yes, not sure of the drw harness/plug you mentioned tho
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 6 Old 05-05-2014, 01:47 PM Thread Starter
cthom388's Avatar
What exactly do you mean when you say aside from the automatic stuff?
1995 F250 4X4 Zf5
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
post #4 of 6 Old 05-12-2014, 07:24 AM Thread Starter
cthom388's Avatar
For anyone that reads this it is not a plug and play it requires quite a bit of re-pinning.
1995 F250 4X4 Zf5
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
post #5 of 6 Old 05-12-2014, 08:38 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Which part requires re pinning? The auto has a Trans harness that controls it, where as the 5 speed does not
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 6 Old 05-12-2014, 11:06 AM Thread Starter
cthom388's Avatar
The tps is wired differently as well as the wiper control system. There are a few more interior things as well.
1995 F250 4X4 Zf5
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
