Supercab seats on regular cab pan? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-24-2014, 06:36 AM Thread Starter
cthom388's Avatar
I have been doing some researching on taking the 40/20/40 seats out of a supercab and putting them on a regular cab. I know that the factory seat pan out of the supercab is not compatible with the regular cab but what i was wondering is could i remove them from the pan and bolt them to my bench seat pan?
1995 F250 4X4 Zf5
  • TS 6 POS Power-Struck Tunes
  • 3" Silverline Dp to Straight Pipe
  • Custom E-Fuel/Regulated Return
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
post #2 of 7 Old 04-24-2014, 05:41 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
As long as you have the super cab parts off then yes, you need the single or crew cab pan and the tracks with it it will bolt rite up
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 7 Old 04-25-2014, 07:17 AM Thread Starter
cthom388's Avatar
Thanks for the info! So when you say the supercab parts you just mean the frames they are on if im correct? So i can just unbolt them from the 3 seperate supercab frames and bolt them to the Non power bench seat frame?
1995 F250 4X4 Zf5
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
post #4 of 7 Old 04-25-2014, 07:38 AM Thread Starter
cthom388's Avatar
I recently bought a 97 F350 xlt parts truck that was hit in the front.The trucks interior is immaculate it is all power. My plan is to take the power doors and put them on my xl as well as the power seats.The seats are the 40/20/40 i am referring to. They are in good shape except the drivers power switch cover is busted so if anybody has one they would wanna sell let me know!
1995 F250 4X4 Zf5
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
post #5 of 7 Old 04-25-2014, 10:44 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Exactly that
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 7 Old 04-25-2014, 10:47 AM Thread Starter
cthom388's Avatar
Thanks man exactly what i needed to know! My names Cody by the way.
1995 F250 4X4 Zf5
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
post #7 of 7 Old 05-05-2014, 04:55 AM Thread Starter
cthom388's Avatar
Well i Just took out the bench over the weekend and drilled all new holes for the super cab frames and bolted them up. I took some BIG flat washers and put them on either side of the floor for added support. I shimmed them up on the passenger side but the drivers needed none at all.They set perfect and look factory.
1995 F250 4X4 Zf5
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
