Putting in sound dampening - Ford Powerstroke Diesel Forum
 5Likes
post #1 of 23 Old 03-11-2014, 01:08 AM Thread Starter
jake1's Avatar
While getting ready to install my cb antenna coax under the carpet I realized just how dirty it was so I decided to tear everything out except for the dash and while interior was gutted I decided lay done noise dampener.
ID:	256138   Click image for larger version
ID:	256146   Click image for larger version
ID:	256154   Click image for larger version
jake1 is offline
post #2 of 23 Old 03-11-2014, 03:48 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Did you not do under the front seats too?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 23 Old 03-11-2014, 04:02 AM Thread Starter
jake1's Avatar
I an going to. I Just ran out of time over the weekend. Got all the carpet pressure washed and all the trim pieces cleaned up and ready to reinstall with New speakers and head unit. Should have it back together this coming weekend
jake1 is offline
post #4 of 23 Old 03-11-2014, 05:54 AM
How much did the sound dampener run for the whole truck if you dont mind me asking??
Tucker
97_Stroked is offline
post #5 of 23 Old 03-11-2014, 06:04 AM Thread Starter
jake1's Avatar
I bought 1 kit of dynamat that was $150 which I got to do the firewall and front floor and I got 6 rolls of peel and seal from Lowe's to do the rear and pillars. Also dynamat will be used on doors . Have not finished yet but so far I have used 3 of the rolls on the rear. The peel and seal ran me $16 a roll.
jake1 is offline
post #6 of 23 Old 03-15-2014, 04:38 PM
Let me know how much sound it actually blocks when you are done.
tucker0104 is offline
post #7 of 23 Old 03-15-2014, 05:02 PM Thread Starter
jake1's Avatar
Will do. Should be done and all back together tomorrow evening
jake1 is offline
post #8 of 23 Old 03-15-2014, 10:38 PM
Pwnm30rdi3's Avatar
I don't want to be the bearer of bad news. Despite popular belief, CLD also known as Constrained-layer damping (I.E. Dynamat or Peal n' Seal) does not actually deaden sound. It simply absorbs vibrations, hence why it is so popular in the auto audio industry.
Before you put everything back together I suggest you buy some CCF and / or MLV. CCF = Closed Cell Foam , MLV = Mass Loaded Vinyl.
While a good dampener is good at removing vibrations it does a poor job at blocking sound. Studies have shown that 25% coverage of dampener is more than enough. Actually, Covering any more than 25% of you interior with dynmat shows very little return on investment.
MLV is what you want to block sound. This is heavy duty stuff and comes with a hefty price tag.
If you want to know more just ask!
Source: I'm a sound engineer.
1997 F350
Mahle Ceramic Coated Pistons (De-lipped), Billet Crower Connecting Rods, DI Chromoly Push Rods, Beehive Valve Springs, Fire Ring Headgaskets, ARP Head Studs, Mike's Main Girdle, Melling LPOP, Terminator Dual HPOP, 300/200 Injectors, Dual SD Fuel Pumps, Billet Aluminum Intake Plenums, 6.0 Mishimoto Intercooler, Compound Turbos (Primary = 62/68 & Atmospheric 82/88), John Wood Tranny, 4921 Transmission Cooler, Batteries Relocated to Bed
Pwnm30rdi3 is offline
post #9 of 23 Old 03-15-2014, 10:57 PM
knuckledragger5's Avatar
Quoted: 9 Post(s)
CCF is great at absorbing sound, not blocking it but absorbing it. CCF works great inside your doors.
I was just doing some research.... Mass Loaded Vinyl~MLV~ 2 Pound~TM Soundproofing.com that stuff is awesome! if i ever pull my interior Im gonna lay the 2lb per sq foot down on the floorboard.
2016 Platinum Tri Coat CCSB F250 Lariat Ultimate, FX4, Factory 20's with the TOYO ATII's
damn trucks loaded, seriously! it has heated rear seats! WTF!
***SOLD***
06 F250 CCLB Lariat FX4
por vida
knuckledragger5 is offline
post #10 of 23 Old 03-15-2014, 11:33 PM
Pwnm30rdi3's Avatar
It's some really great stuff! I did my entire interior with CLD, CCF, & MLV.
The only locations I haven't done are the a-pillars and behind the dash.
Right now my biggest issue is wind noise. Damn OBS trucks have awful window & door seals.
If I remember properly used about 7 sq/ft of material in each door. (I attached the sound deadener to the outer skin of the door) I added roughly 20lbs of material to each door. My doors no longer sound & rattle like a tin can when they shut, instead I get a nice thud.
I had a scrap piece of MLV laying around so I took a picture (1.5lb per sq/ft):
1997 F350
