Intermittent Wipers acting up - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Patrick Feeley
post #1 of 4 Old 02-10-2014, 04:56 PM Thread Starter
BLIZZ's Avatar
On some positions of the rotating switch the wipers refuse to work unless i wiggle the turn signal arm ...and when it does work i can hear a switch clicking under the glove box , is there anything that i can replace to fix this problem .
94 F350 Dually 4 door, stick, Raven Black , stock
BLIZZ is offline
post #2 of 4 Old 02-10-2014, 06:22 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
You could replace the whole assembly. There was a post on one of the forums way way back that described taking apart the switch and cleaning the contacts, but I'm sure it's been archived eons ago. I'll see if I can find the text of it.
Added in edit: From way back in 1999, here's the post I am referring to above: Wiper Delay, Relay
Cheers!
madpogue likes this.
Patrick Feeley is offline
The Following User Says Thank You to Patrick Feeley For This Useful Post:
BLIZZ (02-11-2014)
post #3 of 4 Old 03-09-2014, 07:05 AM
nra1ifer's Avatar
I have had good luck cleaning that switch. Take a pocket knife and pry off the cap on the end of the switch arm. I used a cotton swab (or maybe a foam swab, can't remember) and cleaned that entire area. Has worked good since.
nra1ifer
1995 F250 Ext. Cab 7.3L PSD
I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them.
nra1ifer is offline
The Following User Says Thank You to nra1ifer For This Useful Post:
BLIZZ (03-10-2014)
post #4 of 4 Old 03-29-2014, 08:53 AM Thread Starter
BLIZZ's Avatar
Your method worked ..whats inside is some sort of grease and it melts and gummed up the contacts brake cleaner is needed to wash it out ...pay close attention on how it comes apart .
BLIZZ is offline
