Guages - Ford Powerstroke Diesel Forum
post #1 of 10 Old 01-22-2014, 04:37 PM Thread Starter
L84HNTN's Avatar
Guages
How in the heck does one get the speedometer to stop bouncing?
L84HNTN is offline
post #2 of 10 Old 01-22-2014, 06:42 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
Usually by changing the Vehicle Speed Sensor (VSS) located in the rear axle "pumpkin". You might also need to check the rear gear tone ring to make sure it is OK if that doesn't fix it. Cheers!
Patrick Feeley is offline
post #3 of 10 Old 01-22-2014, 07:54 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Sometimes cleaning the vss will also get you by, but swapping it is recommended
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 10 Old 01-25-2014, 10:55 AM Thread Starter
L84HNTN's Avatar
I changed the VSS but no luck and the gear tone ring looks fine. Is there some sort of a electronic deal inside the instrument panel that could have dust or something thats not allowing a true signal from the VSS?
L84HNTN is offline
post #5 of 10 Old 01-25-2014, 01:05 PM
Quoted: 54 Post(s)
Yes, the PSOM is behind the speedometer, and if you're sure the VSS and tone ring are fine, the PSOM is next on the suspect list.
Does your cruise control work?
I was totin' my pack along the dusty Winnemucca road,
When along came a semi with a high an' canvas-covered load.
"If you're goin' to Winnemucca, Mack, with me you can ride."
And so I climbed into the cab and then I settled down inside.
madpogue is offline
post #6 of 10 Old 02-08-2014, 10:59 AM Thread Starter
L84HNTN's Avatar
Okay so I pulled everything and rolled the gear ring the tone ring in my diff looks like the one I just bought brand new. No teeth are shorter and theres definitely none missing and no cracks. i did however screw up and buy a napa sensor whereas i shoulda known better so possibly it was a bad sensor to begin with? any help is appreciated.
L84HNTN is offline
post #7 of 10 Old 02-12-2014, 04:08 PM Thread Starter
L84HNTN's Avatar
my cruise control doesn't work right and now the speedo is staying at zero
L84HNTN is offline
post #8 of 10 Old 02-12-2014, 04:09 PM Thread Starter
L84HNTN's Avatar
and the tranny is still goofy
L84HNTN is offline
post #9 of 10 Old 02-12-2014, 05:06 PM
Quoted: 54 Post(s)
Does the odometer display a number?
madpogue is offline
post #10 of 10 Old 02-18-2014, 07:10 PM Thread Starter
L84HNTN's Avatar
yes the odometer still works
L84HNTN is offline
