Gauge Cluster - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-21-2014, 04:56 PM Thread Starter
Gauge Cluster
I've got a 97 F350 and I cannnot figure out how to remove the PRND21 selector from the gauge cluster. Also, how do you guys get your hands back behind the cluster to remove the connectors that are pluged in?
Thanks,
-A
*Cannon* is offline
post #2 of 6 Old 01-22-2014, 03:27 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Remove the dash overlay, there are 4 screws holding the cluster, there is a small orange wire holding the prnd21 to the shift arm, and lean it out, disconnect the 3 harnesses in back, remove the see through portion of the cluster and the shift selector should come out
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
The Following User Says Thank You to 351fifty For This Useful Post:
*Cannon* (01-22-2014)
post #3 of 6 Old 01-22-2014, 03:29 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Here is a tach install write up, but works the same for what your wanting
Older F Series .net ? View topic - HOW-TO: Install Instrument Cluster with Tach
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #4 of 6 Old 01-22-2014, 01:13 PM
Quoted: 50 Post(s)
If you're talking about how to remove the pointer and the cable, you don't. Unless you have to, of course. It's part of the cluster. Disconnect the cable from the selector on the column.
To disconnect the harnesses, you pull the cluster out far enough to reach them.
madpogue is offline
The Following User Says Thank You to madpogue For This Useful Post:
post #5 of 6 Old 01-22-2014, 04:30 PM
L84HNTN's Avatar
there should be two little screwsin the face of the panel. you'll need to use a flash light to see them. there are two slots below the PRND21 the screws will be in there. then it slides out the bottom.
L84HNTN is offline
The Following User Says Thank You to L84HNTN For This Useful Post:
post #6 of 6 Old 01-22-2014, 07:04 PM Thread Starter
Thanks guys, I got it to work! You guys are awesome!
*Cannon* is offline
