Power windows - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-09-2014, 06:29 PM Thread Starter
That Other Guy's Avatar
Quoted: 4 Post(s)
Power windows
Well my truck was involved in a wreak with a guard rail by the PO and the driver front as well as passenger rear windows wont do anything on their own. When the switches are hit you can hear the motor turning and trying to catch the gear but it wont catch and move the window.
My question is with a hard hit like that is it possible to knock the assembly out of whack where the gears don't contact each other and how can I check this? I have no expierence with window motors but if pointed in the right direction I can knock this out just need to hear from someone who has been in there and can give me a heading.
97 toredor red metallic f350 XLT CCLB ZF5 7.3 4wd
HPO X-over, riff raff up pipes, 1.00 housing, WWII, 3" dp, 4" exhaust, Tymar intake, riff raff boots, 6.0 fan, tow pig in progress
15 white wrangler jku auto 4" MOPAR lift, fox remote res shocks, fox dampner, black rufino nitros, sun shades, hand grips, floor mats, blah ,blah.
00 Dutchman classic 30' 5er
GN attachment in pin box, new roof compliments of wood rot due to leaks, updating interior currently a work in progress.
That Other Guy is offline
post #2 of 9 Old 01-09-2014, 06:39 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
You can remove the motor insert ball bearings (I used bb's from a BB gun) in where all the broken plastic falls out , it sounds like the plastic bushing shattered
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 9 Old 01-16-2014, 07:52 AM Thread Starter
Quoted: 4 Post(s)
Thanks ill give that look today if i get to it. Im assuming that the motor needs to come out right.
post #4 of 9 Old 01-16-2014, 07:55 AM Thread Starter
Quoted: 4 Post(s)
^^^^ Not entirely sure why i have two accounts on here but it was weird seeing that, took me back for a minuite.
Can mods delete that other account? I spose i started back when i had my duramax and knew others on here with fords.
post #5 of 9 Old 01-20-2014, 11:27 AM Thread Starter
Quoted: 4 Post(s)
Am I right in assuming the motor assembly needs to be pulled to fix this or can I access it without pulling it.
post #6 of 9 Old 02-19-2014, 07:21 PM
Quoted: 5 Post(s)
Pull the motor, and get these:
http://www.autozone.com/autozone/acc...ier=426078_0_0_
pull the cover off, clean out the grease and broken plastic. cycle the motor a few times to get the remaining plastic bits out, and reassemble using some white lithium grease (sparingly). reinstall.
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #7 of 9 Old 02-20-2014, 03:32 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I used bb's for a bob gun honestly, they metal, no plastic to break, did this on a buddies truck, no issues yet
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 9 Old 02-20-2014, 06:01 AM
Quoted: 5 Post(s)
I used bb's once too in a pinch, but over time they will chew through the large gear, which I have yet to find a replacement for.
ianstew is offline
post #9 of 9 Old 02-20-2014, 01:54 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Haven't had that problem, guess that's why ford used plastic to begin with
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
