power locks quit - Ford Powerstroke Diesel Forum
post #1 of 14 Old 01-08-2014, 03:41 PM Thread Starter
power locks quit
I did some searching but didn't come up with much, maybe Im searching the wrong things.
96 obs cc power door locks quit, all of em.
They started working off and on and then all together quit.
checked the fuse and put in a new switch on the driver door.
Im heading to my buddies shop on sunday to get some help. I am no electrical guru by any means. Any pointers or sources would be much appreciated
thanks!
Jwood is offline
post #2 of 14 Old 01-08-2014, 04:45 PM
I don't have any help, but you're not locked in there are you?
2004 F-250, ZF-6, 03 turbo 4" mbrp exh. PHP reprogrammed FICM, sct X3, egr delete, auto meter ultra lite boost & pyro, arp head studs, firestone destination m/t's. ccv mod, mag hytec diff covers, 35% tint, dieselsite coolant filter, cat elc, B&W gooseneck hitch.
screamin7.3 is offline
post #3 of 14 Old 01-08-2014, 06:41 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Tried pass side switch too?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 14 Old 01-09-2014, 06:06 AM Thread Starter
passanger side switch also does nothing.
could it be the door lock actuator itself?
would the driver side front door not working cause the other 3 to not work?
I think its gotta be some kind of switch or fuse block somewhere since nothing at all works.
Windows still work fine, not sure if thats any help?!
Jwood is offline
post #5 of 14 Old 01-10-2014, 04:49 AM
m j
they get power from a single point on driver side.
it will not be a switch IMO
1997 F250 rclb 4x4, Comp910s, SRP1.1, Irate T4 s468,FullForce 350/200, homebrew efuel with i̶n̶ ̶t̶a̶n̶k̶ ̶a̶e̶r̶o̶m̶o̶t̶i̶v̶e̶ ̶1̶1̶1̶4̶2̶ A1000 5/8" drawstraw, Diesel Innovations fuel rail feed fittings, balljoint D60f Detroit Locker, zf5 sachs K70263-01CB ceramic clutch , Grizzly locker 10.25, 315/75/16 Wrangler MT/Windowed 7.3 Oct 9/14
m j is offline
post #6 of 14 Old 01-10-2014, 06:07 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I've had an issue in my crew cab with the locks, swapped both buttons, cleaned off the terminals and worked like new again
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 14 Old 01-10-2014, 06:08 AM Thread Starter
If the driver door lock actuator is bad, will that cause the others to fail?
Jwood is offline
post #8 of 14 Old 01-10-2014, 11:29 AM
farmallcrew's Avatar
Check the wires going into your doors. I had a issue with my driver rear window would only go down when you pushed the button, it wouldn't do anything when you push the button in drivers seat only back at the window. Come to find out when someone must have kicked the wires in he door jam when they got out, because they were kinked opposite of what they should be, and opening and closeing of the door, pinched and cut the wires.
So check you door wiring on the back doors.
OHHH and by the way if it is that, it sucks working in that tiny small of a space, i soldered and crimped the wires together, and tapped them all back up and put them back in their natural state.
1997 F-250 Crew Cab 7.3 4x4 (truck built 12-97)
2 - 8" Mitre cuts
Bully Dog 6 pos chip
Dfuser 18K module
FPR shimmed
RECON Smoke AMBER roof lights
Fire and Ice lightbar under tailgate
ITP Overboost Annihilator
Not running fire company at the moment but still on the truck
2 - 5 ft. FireStik Antenna's hooked into BC 350c Scanner
Vector 7 pod
Soon to be on truck:
Intercooler, new HPOP, straight axle, New OBS starter
farmallcrew is offline
post #9 of 14 Old 01-11-2014, 12:48 PM
I have 2 acurators sitting on my desk for sale, if you want them, their plug and play, real easy to change out.
davidw221 is offline
post #10 of 14 Old 01-11-2014, 12:50 PM
Thats what happened to mine door lock, had to change them out.
