Removing the dash to do stereo noob help - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-01-2013, 06:07 PM Thread Starter
Dos anyone know how to remove the dash to remove the stereo?
Some Drunk Guy is offline
post #2 of 7 Old 12-01-2013, 07:01 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Is it a factory head unit, you shouldn't have to remove the dash for anything other than major wire surgery or additions to said harness
They sell a tool at most stores (walmart) to remove the head unit or you can bend up a coat hanger for it
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 7 Old 12-01-2013, 08:26 PM Thread Starter
It's an aftermarket deck (crappy Panasonic) , it came with the truck and I don't have the removal keys, was going to try to remove it
post #4 of 7 Old 12-02-2013, 03:41 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Pop your glove box out and take a look at the side of it, there are tabs on both sides that will pull out and the head unit should slide out from that point
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 7 Old 12-02-2013, 03:47 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Just buy the removal tool off somewhere like ebay. Shouldn't cost more than a few dollars for the special tool. Way better than taking the dash completely out
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #6 of 7 Old 12-02-2013, 03:53 PM
elchaseo's Avatar
Quoted: 8 Post(s)
They keys aren't much to buy but you can make do with other things like a few skinny precision screwdrivers to release the clips. Also buy the harness that plugs into the factory radio plug. It will make your life very easy as you can wire up the two harnesses on a work bench and just plug it in
2015 F250 Lariat- CAI, CCV Reroute....more to come
elchaseo is offline
post #7 of 7 Old 12-02-2013, 04:34 PM
Quoted: 8 Post(s)
I bet if you went to a local stereo shop and asked nicely they might pull the stereo out for you. It literally takes 5 seconds to pull the stereo out with the right tools.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
