how to help - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-21-2013, 07:55 PM Thread Starter
spartan-alteran's Avatar
how to help
alright I just got this 1000w subs amp and capacitor and all the wiring but I need a box to fit in the back of a crew cab but I cant find any box for it 10"x8" subs to fit in the back wat did you guys do for this and how did you brace it to the cab !? and any blueprint ?? for making a box of my own
spartan-alteran is offline
post #2 of 5 Old 11-22-2013, 05:16 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I used shallow mount subs because the back seat simply doesn't go that far forward, with shallow mount sub boxes (off the shelf stuff) and moved the rear seat forward about 2 clicks, just screwed everything to the back wall
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 5 Old 11-22-2013, 05:18 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Here is a pik of amps and wiring
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #4 of 5 Old 11-22-2013, 08:12 PM Thread Starter
no rust or water coming in cuzz of the new holes ?
post #5 of 5 Old 11-30-2013, 01:19 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Only holes I had were from bolts into the wall but didn't use huge screws and they were self tapping so nice and snug, now if you ever remove them then it wallers the hole a bit and that can happen, but I'm also from the south
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
