Tank selector keep blowing #6 fuse - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-21-2013, 09:48 AM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Whenever i use my tank selector im pretty good about keeping the usage the same between the tanks so my selector doesnt go bad but i have a problem with when ever i hit the switch to say check the level in the other tank then flip it back a few secs later, it blows the fuse which then makes both tanks read empty.
Is this a no no to swap back and forth, not so much right away but flip it, wait for it to level out, then flip it back to the one i was using. When the fuse is good everything flips all good and dandy, it just seems like if i use it more than once in a trip it blows the fuse. Any ideas guys?
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 5 Old 11-22-2013, 09:39 AM
Quoted: 54 Post(s)
That should not blow the fuse. I don't have the owner's manual in front of me, so remind me; is fuse #6 for the selector or for the gauge?
madpogue is offline
post #3 of 5 Old 11-22-2013, 10:14 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Its for the selector itself, yea it doesnt make any sense to me either. Its like clockwork it will do it, it will let me switch once just fine but if i do it more than once at least within a minute or 2 it will cut the fuse.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #4 of 5 Old 11-22-2013, 10:30 AM
RedneckYankee's Avatar
You may have a plunger in the solenoid that is hanging on your selector valve causing an over amperage condition while switching between tanks. You may be able to see an amp spike with an analog amp meter. Unless you have a direct short but if that was the case you'd blow the fuse every time you tried to swap tanks.
David
"Hold my beer and watch this"
2005 Excurstion Limited RWD
Sinister EGR Deleate
SCT Tuner MPT Custom Tune Econ/Perf
Dash Boss Monitor
Blue Spring Upgrade
Nitto Terra Grappler 285/75/16
Bilstien 4600 shocks
No Kitty
4" Straight piped
Studded
Updated Stand pipes and Dummy Plugs
1996 F250 XCLB 4x4
4" Ruff Country Lift
Ruff Country N2O Shocks
RedneckYankee is offline
post #5 of 5 Old 11-22-2013, 10:42 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
I have noticed that the volt gauge on the dash drops pretty far when switching tanks but wasnt sure if that was normal. Now that i think more, its possible its only doing it when i switch it a certain way which would indicate that way is getting hung up...ill have to test that.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
