Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 94-98 7.3L Forums > 94-98 7.3L Interior Discussion
Old 07-28-2008, 03:59 PM
choctaw choctaw is offline
I'm #1 in the #2 Business
97 A/C Problems
My brother's 97 a/c will blow cold air, but when he turns the knob to max it blows the same.
Is it the control, a vacuum problem, or am I missing something?
It's hot here in Texas and all help will be appreciated.
Old 07-28-2008, 04:03 PM
lamarmathis lamarmathis is offline
when u turn it to max ac it should blow the same,the diff is in max the air is pulled from inside the cab rather than from outside
Old 07-28-2008, 04:10 PM
OK, but in my 06 there is a definate difference in how quickly it cools down, and there is a different sound as if it is blowing harder. His does not make this sound, or increase in cooling.
Old 07-29-2008, 04:37 AM
Old 07-29-2008, 06:47 PM
Big K Big K is offline
There is a vaccum leak somewhere, because it will cause the vent from the OUTSIDE to close shut and the noise/speed of the air will be different....
Take a look under the hood for the vacuum lines, they can be black or white depending on if they have been changed in the past...should be near the passenger side....
Old 07-29-2008, 06:56 PM
Thanks....
Old 08-12-2008, 06:47 AM
Pest007 Pest007 is offline
I had a problem with a vacuum leak from the hose that goes to close the door to recirculate the inside air, just start the truck, turn it on normal air, the look at the position on the lever on the top of the blower area where the actuator is (should have a white vacuum line to it) and then turn on max air, and see if it moves, it should, if not pull the line and see if it is sucking air, if not you need find the leak or change the switch, mine was the line itself and ran a new one.
Old 08-12-2008, 07:05 AM
Thanks for the input guys, I should have posted this earlier.
It was the white vacuum hose under the hood on the actuator, had to replace about 8".
My brother says thanks!!!
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
