door handle - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-19-2013, 09:37 PM Thread Starter
door handle
anyone know how to "upgrage" the handles i broke mine yesterday. cheap *** plastic
96-Rollin-Red is offline
post #2 of 7 Old 10-20-2013, 05:14 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The metal ones from the 80-86 trucks
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 7 Old 10-22-2013, 11:23 AM
metal handles in the "Help" section of auto store work great. While you have it apart, tighten screws and grease everything.
'97 XLT F-350 Crew Cab LB, 240,000 miles, 20x10 MB Rocker Rims, with TOYO 35x12.50x20, tool box, Swamps TS tuner, MBRP exhaust S&B Intake, Auto Meter gauges.
xjaddiction is offline
post #4 of 7 Old 10-23-2013, 05:59 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
There is a reason your plastic handle broke
The cable is stretched or your door is cracked. They are the ONLY 2 reasons the OEM handle brakes.
If you put the metal handle on you WILL tear the door
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #5 of 7 Old 10-28-2013, 07:12 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
What really suks is when the door brakes at the handle mount instead of the handle breaking
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 7 Old 10-29-2013, 05:18 AM
Ranzan's Avatar
Quoted: 23 Post(s)
x2 then having to pull the panel with the door closed
Wes
2010 F350 CCLB 4x4 Lariat Sterling Grey
11 and up Console upgrade
Fully deleted DFC Long Block
2 1/2 levelling kit
1995 F350 CCLB XLT Stock for now....
1997 F350 CCLB 4x4 5 speed Tourmaline green
DDP Stage 1`s
08 Bucket console upgrade ( SOLD )
Ranzan is offline
post #7 of 7 Old 10-29-2013, 05:38 AM
if your truck handle gives you troubke, take pnnel off. my assembly was loose with hardened dried out grease. tightened up, cleaned, with new grease still broke the old week plastic handle. i replaced with metal, works great.
on the handle mount braking, role window down and use outside handle.
