Glow plug indicator lights - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-18-2013, 05:42 AM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
The PO of my truck had 4 holes drilled in the dash for what im assuming was for a CB mike holder considering the holes on the back of the center console and the antenna mounts that were in the bed before i tossed them.
Well me having absolutely no use for any nonsense CB i figured id throw some LEDs in there to indicate when my GPs are on since its getting cold out ill be needing them. Figured id throw it up and see what you guys think.
They are a tad bit bright during the night so if i get the drive ill tint them with a sharpie or something. Im gonna ad some to my SD too
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 6 Old 10-18-2013, 05:53 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
Thats kool looking!
2000-7.3L is offline
post #3 of 6 Old 10-18-2013, 10:13 AM
CSIPSD's Avatar
Thats alot of LED!!! LOL...
I have the same thing on my A-pillar. Make sure you have them hooked to the SUPPLY side of the GPR, so that your not just one the switch side of the relay.
Reason is if your on the small post, switch side then you dont know if the relay is really working, only that the PCM is commanding the relay to close.
This video shows how long the glow plugs are on even after the WTS light goes out...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #4 of 6 Old 10-18-2013, 10:25 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Glow plug light - YouTube
Yes sir i put it on the supply side i almost did the switched but then thought that exact thing. Reason for 4 LEDs is 2 fold. 1) PO had 4 holes drilled, 2) so i could wire them in series without screwing with resistors with reasonable safety (LEDs are 3v a piece). It was interesting seeing exactly how long they really are on for even AFTER you start the truck.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #5 of 6 Old 10-18-2013, 11:27 AM
Quoted: 50 Post(s)
Why does that remind me of: http://ih2.redbubble.net/image.13778...0,white.u1.jpg ?
Glow plug indicator - dash voltmeter left of center.
madpogue is offline
post #6 of 6 Old 10-18-2013, 11:40 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Damnit you figured it out, ive mastered time travel. Btw the goverment screws us all...well i guess thats already known dont need a time machine to know that.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
