anyone eles have this prob!? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-14-2013, 10:06 PM Thread Starter
spartan-alteran's Avatar
k so ever since I weird up my new stereo into my truck every time I turn on the headlights my stereo goes off then back on again ? and I rewired my ground to another place also, new fuse and everything and still doing this should I get a new wire installed for power ??
spartan-alteran is offline
post #2 of 4 Old 10-14-2013, 10:31 PM
JSchuricht's Avatar
Could be a few different things. Are the lights HID? Sometimes HID's produce enough interfearance to cause weird things like shutting off your radio. The next thing I would do is replicate the issue with a multimeter hooked up to both the power and ground that the radio is using. Watch for the voltage to drop. If the voltage drops when you turn the lights on, isolate the issue. Start by moving the multimeter ground to the chassis and see if the voltage still drops, then move it back to the radio ground and use a different power source to check for voltage drop. If another power source is also dropping voltage then start looking at chassis grounds, battery connections and the alternator.
JSchuricht is offline
post #3 of 4 Old 10-15-2013, 03:43 AM Thread Starter
non I still got the stock light and thanks for the info il tri it as soon I can find a multimeter
post #4 of 4 Old 10-15-2013, 04:24 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Also check the headlight harness, it draws a lot of power, a few guys have just wired them to a relay to draw straight from the battery instead of the switch
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
