Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 94-98 7.3L Forums > 94-98 7.3L Interior Discussion
Old 07-07-2008, 06:44 AM
moto moto is offline
power window problem
need help with my windows 1997 f350 crew cab back window went down fine won't come back up thanks for any help
Old 07-07-2008, 07:04 AM
SCUFFY828 SCUFFY828 is offline
SUPERDUTY GURU
try both switches , need to test for power on switch to see if it has power , if it went down my guess would be that the motor is stuck, pull the door panel ad tap it with something and i bet it will go up
Old 07-07-2008, 07:08 AM
Thanks will give it a tap tonight
Old 07-07-2008, 07:26 AM
jfines@cox.net jfines@cox.net is offline
I had mine do that last summer. I pulled off the door panel and used a pry bar and it popped then started working correctly.
When I got the truck the same window did not work. The clip on the electrical connection had broken and I used a little glue to put it back in.
Old 07-15-2008, 12:01 PM
wires between door and truck broken spliced and working good thanks for info
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
