40/20/40 in the rear?? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 09-06-2013, 09:12 PM Thread Starter
Been searching google for a bit and can't find an answer so I'll ask here
Will a 40-20-40 front bench seat from a 4door crew cab fit in the rear of a 4door crew. I got a 96 F350 4door and would like to replace the rear bench seat with a front 40/20/40 with the center flip down back rest. Is it a direct bolt in is basically what im asking.
Buckhunter8813 is offline
post #2 of 11 Old 09-06-2013, 10:35 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
direct bolt in provided you use the front seat from a crew cab or the seat from a regular cab. Cant use super cab seats
Trucks and parts............
kanuck15 is offline
post #3 of 11 Old 09-07-2013, 09:47 AM
^^^^ this.i used a cc front in the rear of my cc.but there is a trade off,you lose some room behind the seat and the space under the seat.under space is minimal after the swap.not sure if you can swap the seat brackets between the two and keep the under space,i have not tried that too see.
96 f-350 cclb 4x4 auto
97oneton is offline
post #4 of 11 Old 09-07-2013, 10:22 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
You can't swap the brackets, the crew cab seat uses a large pan to hold the seats together
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 11 Old 09-13-2013, 09:26 AM
BBslider001's Avatar
Quoted: 5 Post(s)
Yes, it is a direct bolt in. I swapped my rear seat with my front for a bit to see if I would like it. Took about 45 min to do the swap.
Sent from AutoGuide.com App
Byron
1999 F-350 E99, 4x4, ZF6, RiffRaff FRX, AFE CAI, CAT gone bye bye
1997 F-350 CC DRW, 7.3 PSD, SOLD
1995 F-350 CCLB 4x4, ZF 5, SOLD
2011 34' Sundance by Heartland TT
BBslider001 is offline
post #6 of 11 Old 09-15-2013, 08:08 AM
leojr's Avatar
Quoted: 4 Post(s)
Did you? I want to do this because I think it would make riding in the back seat more comfortable.
Denton, TX
I envy those that know exactly which modification to make and in the most logical of sequences. But not enough to trade for my meanderings and misfires.
1996 F250 crew cab/short bed, 4x4, auto PSD, 6637 air filter, interior grab handles, stainless window vents, remote door locks work with engine running mod.
leojr is offline
post #7 of 11 Old 09-15-2013, 12:13 PM
Quoted: 5 Post(s)
I liked it ok. I did it to have a more comfortable front seat but then my wife had to climb over it to get in the back when she needed and that was a PITA. Just depends on what you define as comfortable I guess. You are in Denton? My wife and I lived there for a year. She worked at UNT and I worked at the Outback. Good times.
Byron
post #8 of 11 Old 09-24-2013, 08:24 PM
leojr's Avatar
Quoted: 4 Post(s)
I don't follow what has to be climbed over... Maybe the front seat just takes up so much rear room that you can't slide in from the doors? Dunno...
Outback, just down the highway from the beer barn. Grew up in Denton, still remember driving thru the beer barn for a draft beer. Ah the good ol days.
Denton, TX
leojr is offline
post #9 of 11 Old 09-24-2013, 09:10 PM
Quoted: 5 Post(s)
Meaning the bench seat doesn't have a split in the middle like the buckets do.
Byron
post #10 of 11 Old 09-25-2013, 01:43 PM
smcox1's Avatar
Quoted: 3 Post(s)
2008-f250 powerstroke
2004-f350 powerstroke
2003-f250 powerstroke-gone
2002-f150 Supercrew
1995-f150 Crewcab centurion conversion
smcox1 is offline
