40-20-40 - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-27-2013, 09:45 AM Thread Starter
Quoted: 4 Post(s)
I have a 1995 F 350 XLT and I need a drivers seat. It's the captain seat. Anybody have one for sale or know where I can get one? thanks
timlsalem is offline
post #2 of 9 Old 08-27-2013, 10:09 AM
Quoted: 58 Post(s)
Which cab?
madpogue is offline
post #3 of 9 Old 08-27-2013, 06:10 PM Thread Starter
Quoted: 4 Post(s)
it's a crew cab
post #4 of 9 Old 08-27-2013, 06:39 PM
Quoted: 58 Post(s)
CC or RC seat will bolt right up. EC seat will not.
madpogue is offline
post #5 of 9 Old 08-28-2013, 02:58 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
If its a seat only then any cab and bronco will bolt to your existing tracks, but if you need tracks too it will be crew or reg cab only
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 9 Old 08-29-2013, 04:38 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
WHat is wrong with your drivers seat?
BTW a Captains chair was only available in a bronco and super cab and is NOT a 40-20-40
If your drivers side of the 40-20-40(the 40) is soft and showing wear, swap it with the passengers side.
You need to remove the whole seat from the truck(the 40 the 20 and the 40 as one unit).
Then remove both "40" sections.
Then strip both seats of the fabric and foam
Swap them on to the other frame.
You will need to cut little holes for the lumbar controls and trim screws.
there will be holes towards the "inside" but the "20" section hides them
then you will have a like new seat on the drivers side
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #7 of 9 Old 08-29-2013, 05:14 PM Thread Starter
Quoted: 4 Post(s)
I don't know what to tell you. My seats are captain seats and it's called a 40-20-40 meaning there's a middle consule that has a door that opens up on the top. The frame on the seat above the track has a 3" break in it. The back sits at a 30 to 35 degrees recline and is getting worse.
post #8 of 9 Old 08-29-2013, 06:13 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Use a seat from any cab just use the frame and keep your padding/fabric even an explorer seat will bolt up, won't match tho
Brad you could get captains chairs in a reg cab (lightning) and some other models too
Btw a captains chair is described as a single seat with arm rest
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 9 Old 08-30-2013, 04:01 AM
Quoted: 4 Post(s)
So which do you have?
Captains chairs have 2 seats w a center plastic console.
a 40-20-40 is 2 seats(the 40 and 40) with a center flip up seat(the 20)
