Falling headliner, how to fix it? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 08-20-2013, 04:45 AM Thread Starter
My headliner is starting to fall off (the fabric)
How can I fix this before it gets worse ? Is there any type of glue or something that won't make it look like a*s ?
Thanks.
1996 Ford F-350
7.3 Powerstroke, manual 5 speeds, 4x4, Crew Cab, Long Bed, Srw, 4.10 gears.
1995 Ford Taurus SHO
V6 3.0L DOHC Yamaha, manual 5 speeds, Eibach springs, Koni struts, Quaife ATB diff, Brembo brakes, K&N filter, solid motor mount, 2x Pionner PIAA 10" subs + JBL GTO 301.1II amp, Cobra CB radio and wilson antenna
crazy_canadian is offline
post #2 of 8 Old 08-20-2013, 04:53 AM
Falling Headliner
Have had the same problem. Prior owner had somehow splashed some ?coffee in a couple of small areas that I noted when cleaning up. Couldn't see it unless you were up cleaning. Upholstery cleaner took off the stain but dissolved that rather weak glue holding the headliner on. I got a syringe and fine needle and squirted small drops of elmers glue through the cloth in a 1" by 1" pattern, and made a brace to hold a pillow with wax paper on it up against the headliner. If you look you can see some of the spots of glue, but I just don't look. Small spots of glue are the key, too much and it soaks through. You can always go back and add some more if there is a droopy spot. Good luck. If you find a better way please post, just incase my cure fails after a while.
2004 F350 6.0, 5R100, SRW, 3.73LS, CCSB, XLT, 163k, second owner as of May 5, 2013: stock except new Clarion CX501 radio and DashBoss/Ipad monitor as my first mods.
End of July, 2013: now has all new fluids/filters, Rotella Ultra ELC, T6, AR9100, blue spring, DashBoss EGT and Fuel Pressure sensors in, not yet wired. Delta at 65mph 8, 70mph 10, running on Gold.
Desert Rat is offline
post #3 of 8 Old 08-20-2013, 12:15 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
If you can peel it back, 3M makes some good spray adhesives that might work for you. Cheers!
Patrick Feeley is offline
post #4 of 8 Old 08-20-2013, 12:21 PM
dannanw's Avatar
Quoted: 66 Post(s)
Garage
yep, most spray adhesives will work
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #5 of 8 Old 08-20-2013, 12:49 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
get a new truck? LOL
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #6 of 8 Old 09-08-2013, 02:52 PM Thread Starter
Thanks. I will try the needle trick. I don't really need a perfect job. It's a 520k KM truck.
1996 Ford F-350
post #7 of 8 Old 10-06-2013, 06:54 PM
Headliner
Thanks.
You can buy a headliner renewal kit on eBay. One afternoon and a little elbow grease.
97 F350 7.3 super cab full bed dually
Autometer Sport Comp II boost and egt
TS 6pos tuner
Clutch clevis mod
Tymar intake
Stancor/White & Rogers GPR
Dyno test 221.5hp @ 187,000 mi. Before mods.
Other mods soon :
diamond back dp and 4in exh
ebp del ped
ccv mod
ww2.
drsmith3 is offline
post #8 of 8 Old 10-17-2013, 03:41 PM
getting it out is the toughest. take it out and peel the old stuff off. its the foam between the colored fabric and the glue that rots away. peel it off, sand it down and put new fabric on. I do this for a living, interior work, not that difficult at all.
f250towrig is offline
