Power door locks - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-30-2013, 05:39 PM Thread Starter
dirtcrew51m's Avatar
Quoted: 6 Post(s)
Power door locks
R\s works, l\s does not, I put a new actuator in it, when I tested the two wires going to it, one wire was -12v to ground, and +12 to ground, when switched, the other only read millivolts, which means there is no power going to that wire, Would it be a switch or should I look elsewhere?
dirtcrew51m is offline
post #2 of 3 Old 06-30-2016, 04:24 PM
SButler83's Avatar
Did you resolve this issue? I have a similar issue. Left switch doesn't work at all, right switch unlocks all doors but doesn't lock any.
SButler83 is offline
post #3 of 3 Old 06-30-2016, 04:42 PM Thread Starter
Quoted: 6 Post(s)
Not yet, but I goofed, left works, right sometimes, but strains, yet works normally with the left switch, I am going to check the wires going through the door and ground. I just hate pulling the door panels off.
