stario ? - Ford Powerstroke Diesel Forum
post #1 of 45 Old 07-24-2013, 10:39 AM Thread Starter
spartan-alteran's Avatar
stario ?
any one ever installed a new stereo into there truck if yea would you have a diagram on wat is wat my new stereo hase less weirs feed into it and the old one a lot more weirs if you can help it be grateful.
spartan-alteran is offline
post #2 of 45 Old 07-24-2013, 11:10 AM
Fantom's Avatar
Quoted: 12 Post(s)
Feedback Score: 4 reviews
It's actually really simple to install a stereo. You need to buy a wire harness and dash kit that will fit your truck. It's about $30. You splice the wires from the new wire harness into the wire harness from the new radio, clip in your dash kit, plug the newly spliced wire harness into the truck's factory radio plugs, slide your radio in and you're done. Can be done in an hour or less.
John
2004 Harley Davidson F250 #1191 - 6.0 Powerstroke
Studded - Lots Of Bulletproof Diesel Parts
Swamps 58v FICM - KC Stage 2 Turbo
Ported Intake - S&B CAI
100,000 Miles
Live in Northern California? Stop in here and say hi
Fantom is offline
post #3 of 45 Old 07-24-2013, 11:45 AM
Snake's Avatar
Quoted: 46 Post(s)
Agreed. There are a bunch of companies selling wiring harnesses that make the installation very easy. No cutting and splicing of wires. Just plug everything together and you're done with the wiring.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #4 of 45 Old 07-24-2013, 12:17 PM Thread Starter
thank for the info I live in a small town so I cud not find some for the year to the new stereo I got a XDMA6370 made by Dual and it fits in the dash and all is just the weirs need to find out wat goes were =P thanks for the info tho ima look online to see if I can find the harness for it just in case tho
post #5 of 45 Old 07-24-2013, 12:21 PM
Quoted: 357 Post(s)
Feedback Score: 5 reviews
I'm sorry........
Does this small town have grammar or spelling classes?
I just had to... I can't even read what you're trying to say
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #6 of 45 Old 07-24-2013, 12:55 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
You will need to make sure you specify if your truck has the premium sound option to get the correct harness adapters. On a non-premium sound truck, the harness plugs that go into the head unit will look similar (premium sound will have one that looks vastly different than the other). Cheers!
Patrick Feeley is offline
post #7 of 45 Old 07-24-2013, 12:58 PM
2000-7.3L's Avatar
Feedback Score: 10 reviews
I can cut plice and install a new deck in 15min! Very easy! Find a wiring diagram, then easy peezy! use but connectors, does the same thing as spending the money on a fancy harness
2000-7.3L is offline
post #8 of 45 Old 07-24-2013, 02:35 PM Thread Starter
Im French that y my English isent that good, and if I could find a good wiring diagram I could do it np I got a 7.3 XL
post #9 of 45 Old 07-24-2013, 02:44 PM
Quoted: 357 Post(s)
I see. My bad buddy!
I would REALLY get the $5 wiring harness so you don't cut into your factory wiring... That is a CHEAP way of doing things!!
Buy it on EBay and splice the wiring harness with your stereos wires (the colors should match)
Studded and Deleted
post #10 of 45 Old 07-24-2013, 03:12 PM
Snake's Avatar
Quoted: 46 Post(s)
For the harness, this place may have them Crutchfield: Car Stereo, Speakers, Home Theater, LCD TV, Digital Cameras
For wiring diagrams, you could join this site and ask Car Alarm, Car Stereo, Mobile Video, and Cruise Control Info for Installers
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
