1996 F350 Diesel Dash Cluster - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-26-2013, 03:40 PM Thread Starter
1996 Ford 7.3L Stroke's Avatar
Anyone know how or if the temperature gauge can be fixed, only part of the dash cluster that doesn't work.....please help!
Sent from AutoGuide.com App
1996 Ford 7.3L Stroke is offline
post #2 of 5 Old 06-26-2013, 07:55 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
Are you sure it is the guage and not the sending unit? I think the gauge itself is replaceable if you can find another, maybe in a salvage yard. Cheers!
Patrick Feeley is offline
post #3 of 5 Old 06-26-2013, 09:07 PM
PowerstrokinIt F250's Avatar
most likely the sending unit, if not though lmc truck sells the guage. I had my dash cluster out to replace the bulbs in it. cant remember exactly how hard it would be just to replace the guage
[IMG]http://i59.tinypic.com/33l06ll.jpg
1995 f350 7.3 4x4 auto 4door long bed 160,000 miles BONE STOCK for now. Cleanest truck in PA
1998 Mitsubishi Eclipse GSX 9.9@ 152mph
2003 Honda Civic daily driver
PowerstrokinIt F250 is offline
post #4 of 5 Old 06-27-2013, 08:43 AM
Quoted: 53 Post(s)
There are two senders, one for the gauge and one for the light. I forget which is which. If you disconnect both and jumper the connector terminal to ground, the light should light up, and the gauge should peg to High. If the needle pegs, the gauge head is (most likely) GOOD, and it's the sender at fault. If the needle doesn't move, then it's most likely the gauge head at fault. It's shared with the oil "gauge". LMC replacement is crazy expensive. You could prob. get a whole cluster for $50 at the boneyard or via craigslist, or the classifieds here on the org or the other forum sites. You don't have to take the whole cluster out, just take the lens (bezel, whatever) off, and the section for the temp and oil gauges comes out separately. Pretty plug-and-play.
madpogue is offline
post #5 of 5 Old 06-27-2013, 11:06 AM
Quoted: 15 Post(s)
IIRC, Gauge sender is on the water pump (sort of on the top), the switch for the light is more over towards the CPS. Cheers!
