Dash Super Duty dash swap - Ford Powerstroke Diesel Forum
post #1 of 20 Old 06-16-2013, 07:49 AM Thread Starter
I know you can swap the seats and steering wheel from the newer trucks into the OBS, but can you swap the whole dash from the 99-07 into the OBS?
Jellyroll is offline
post #2 of 20 Old 06-16-2013, 09:05 PM
JSchuricht's Avatar
Sure but your going to have to be really good at customizing stuff to make it look right. It won't be a direct fit and the gauge cluster won't directly work, however it would make a good excuse to upgrade to a SD PCM.
JSchuricht is offline
post #3 of 20 Old 06-16-2013, 09:34 PM
alaskan155's Avatar
Quoted: 66 Post(s)
aren't the superdutys a tad wider than the OBS?
at least it seems like it is to me, but i may be wrong,
anyway if you do it, it would be cool and take plenty of pictures!!
the airbags would look out of place to me lol unless you use the entire sd harness and wire them up,
2002 F250 7.3/JW Tow master 4r100 212k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles, Redhead steering box
alaskan155 is offline
post #4 of 20 Old 06-17-2013, 10:05 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
It is also a much deeper dash compared to the obs
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 20 Old 06-17-2013, 11:14 AM Thread Starter
Well I can take measurements and cardboard it to see where it hits and how close to the seats it comes. If the 99-03 7.3 computers and everything works with the OBS then no problem switching. I don't mind extra work and maybe even some extra $$. It will be a nice one-of-a-kind truck
post #6 of 20 Old 06-17-2013, 03:54 PM Thread Starter
Forgot one important thing, the HVAC system. How different is it from the 99+?
post #7 of 20 Old 06-17-2013, 08:52 PM
JSchuricht's Avatar
The HVAC shouldn't be as hard as getting everything else to look good. Both systems are vacuum operated, I would suspect that the OBS box would work and you just need the SD ducting with a bit of customization to make it work. The big thing is just going to be getting everything to fit and not look like crap.
post #8 of 20 Old 06-18-2013, 10:09 AM Thread Starter
Good, since I will be using the SDs computers should not be hard making all the buttons work and maybe try to get the overhead computer too?
post #9 of 20 Old 06-18-2013, 10:18 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
If using sd computer too, then go hydroboost brakes and electric vacuum pump
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 20 Old 06-18-2013, 10:22 AM Thread Starter
Alrighty, put that down on the list of things to do.
