Removal of Instrument Gauge Panel - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-06-2013, 02:44 PM Thread Starter
1996 Ford 7.3L Stroke's Avatar
Anyone had the wonderful luxury of removing one of these? I got all the bolts out and unplugged the couple of switches...but there's a white cable that runs in the middle of the bottom side of the cluster....don't know how to release it to pull the cluster out.....help! Lol any info is greatly appreciated
Sent from AutoGuide.com App
1996 Ford 7.3L Stroke is offline
post #2 of 2 Old 06-06-2013, 03:55 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
It goes under the wheel and to the other side onto a lever moved by the gear selector, put your truck in low 1, grab the wire and lift it up a bit
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
