Power Windows - Ford Powerstroke Diesel Forum
Old 03-13-2008, 04:11 PM
Talking Power Windows
I am looking for a good wiring diagram, or some help.
Currently, none of my power door locks work, and only the front power windows work. This is a crew cab, and the only wiring diagrams I can find are for a 2 door, and the color code is wrong.
I have no power to the windows in the rear, and I do not know where the red/blue wirte in the rear door originates....help...
Thanks in advance......
Old 03-14-2008, 02:05 AM
ANYONE???
Old 03-14-2008, 02:34 PM
I dont have a diagram but may be able to help. I had the same problem as you in the past. Check out the wiring under the drivers side sill and also the wiring from the center pillar to the rear door. I found rotting and burnt wiring in those two places. Replaced it all and everything works great.
Old 03-15-2008, 02:06 AM
Thanks!
I will check that and let you know.
