Power door locks - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-15-2013, 09:13 AM Thread Starter
Blazin8556's Avatar
Power door locks
Im installing rke in my truck. Everything was going good till I isolated the drivers door. With my power probe I can lock and unlock the doors. I installed a diode in the line for unlock to have driver door unlock only or all unlock. I can unlock the driver door only orthe whole truck using the power probe. But I lost lock on the driver.door. Even with the switch. Im thinking the diode has shut out ground some how to the lock motor for lock function. Any ideas? The new relays have not been installed yet. Anone have any ideas?
The probe was showing ground when lock motors not active and positive pulse to either line would move the motor. The install seems to be using the same triggers sstup as aftermarket kits. So far the truck has responded to every feature except this.
1995 F350 XLT|DRW|7.3L Powerstroke|1.0 turbo|3" Diamond Eye Downpipe|Straight Piped|EBPV delete|DIY 6637|RiffRaff turbo inlet boot|203* thermostat|IDM mod|CCV|Built E4OD|Derale Trans Pan|Trans Temp Gauge|Explorer RAP RKE. Traded for a chevy
2007 F350 Lariat 6.0 . under the knife already
Blazin8556 is offline
post #2 of 4 Old 05-19-2013, 11:14 AM Thread Starter
Blazin8556's Avatar
Guess I'm gonna install the relays and see if it fixes itself somehow.
post #3 of 4 Old 06-13-2013, 08:36 PM
Electrical Ogre
alberta 7.3's Avatar
Quoted: 113 Post(s)
If you are doing a factory style RKE module, the switches send ground pulses to the module. The module then send power with the correct polarity to the lock motors. You shouldn't need to diode isolate anything, unless you are piggy-backing an alarm/remote start on top of the RKE.
The module has 3 output wires:
driver unlock (goes to one side of driver door solenoid)
Unlock all doors (goes to passenger door(s))
Lock all doors (goes to the "other side" of all the solenoids.)
OBS keyless entry (RKE) retrofit.
Bill
1996 F250 SC/SB 4X4 XLT
1997 F250 RC/SB 2WD project
2008 F350 CC/LB 4X4 DRW Lariat, 3" cow catcher mod
2008 Ranger SC FX4
Originally Posted by weareweird69 View Post
If your posting pictures bill, everyone dim their screens, that CAT YELLOW is bright
Originally Posted by Fordman247365 View Post
Is there anything you DONT take apart and **** with?
Originally Posted by JJFLASH View Post
I still say that those Dodge mirrors have as much business on a OBS Ford as yoga pants have on a fat chick...my .02
alberta 7.3 is offline
post #4 of 4 Old 06-16-2013, 11:27 AM Thread Starter
Blazin8556's Avatar
My donor vehicle is a 96 explorer instead of doing it how it is in the thread. When I hit the unlock button it is supposed to do driver only unlock. Again will open the other three. Seems like the truck may already be isolating the driver door and that might be what's screwing up what I'm doing? I dunno. I had to get the truck drivable pretty quick so I am kinda at a stand still. All the other functions are responding correctly. But the whole unit is pointless unless the door locks work right.
