Changing cluster (dash) lights in 1996 F-250 - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-07-2013, 12:40 PM Thread Starter
Has anyone had any experience changing the dash/cluster lights on their trucks? Someone told me they were sold as one complete set and may cost up to $200.00. However, when I googled it, I think the lights in my truck are just a type of screw in bulb. The numbers at the top of my speedomenter are hard to read due to no light behind them. Also, is this a big undertaking where I can do it in one evening and have it done in a few hours or should I plan to start this on a Saturday morning so I have plenty of time?
Thanks,
1996 F-250 7.3L Powerstroke extended cab. 255,000 miles and strong as ever.
"The nine most terrifying words in the English language are: 'I'm from the government and I'm here to help.'" - Ronald Regan
str8razor is offline
post #2 of 4 Old 05-07-2013, 01:38 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
takes about half hour at most, they are 197 bulbs iirc, same as the cab lights, here is a write up to replace them
Older F Series .net • View topic - HOW-TO: Install Instrument Cluster with Tach
instead of full disassembly of the cluster tho, just flip it over and the tabs in the back just twist out bulbs just slip in to the clips and re install
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 4 Old 05-07-2013, 02:21 PM Thread Starter
Wow, great article 351fifty with great pics to go with it! I think I'll take care of it this evening. Thanks!
post #4 of 4 Old 05-07-2013, 02:28 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
yeah its fairly easy, if you search around there are a few threads on using LED's and changing the dash color as well
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
