Need some help - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-05-2013, 04:26 PM Thread Starter
Need some help
I was adjusting the door bolts on my door..... Well set them to tight and cant open the door now.... How do you take the inside panel off?
2015 F-350 Lariat SRW CC
Sold to my dad:1996 F-350 XLT Crew Cab
2x4 Dually 7.3 with 80,000 miles as of 3-10-15
YJSONLY is offline
post #2 of 8 Old 05-05-2013, 04:31 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
4 screws at the bottom, one screw at top gonna be hidden by the dash, screw in the arm rest, and just pops out from there, you sure it's just not locked?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 8 Old 05-05-2013, 04:32 PM
Its not going to come off with the door shut very well if at all.
Have you tried pushing it closed really hard and jiggly the release?
cfd_shop is offline
post #4 of 8 Old 05-05-2013, 05:17 PM Thread Starter
Yes. I wish there was a easy way on adjusting the bolts!!!
YJSONLY is offline
post #5 of 8 Old 05-05-2013, 05:22 PM
Ok lets take the other side door panel off. Take a look and see how we are going to get the latch to release.
Maybe it will give you an idea how to manipulate the panel to get it loose as well
cfd_shop is offline
post #6 of 8 Old 05-05-2013, 05:24 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
No way unless you break it somewhere
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 8 Old 05-05-2013, 05:33 PM
Lets just ask the question.
How much is a new foor panel and for the price is it worth diddling arounf or do ya cut it off.
Here is where it gets tough. Where do we cut
thats why I suggest remove other side psnel and get a plan
I did this a long time ago the first week I was at a new dealership.
Yhe shop foreman told me " I have done this 30 years and never seen this happen."
Somehow I got it unlatched it just took patience
We will get
cfd_shop is offline
post #8 of 8 Old 05-12-2013, 05:30 AM Thread Starter
Well I was able to monkey with it enough and get it open. I took the bolt off and held it to the door latch. And the door latch release seems weak. So I am going to replace the door latch. Because even if I put the striker bolt all the way out the door still will not open. But if I take the plastic off the striker bolt the door latch will release.
YJSONLY is offline
