Front seat for 96 F-250 Powerstroke - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-26-2013, 11:08 AM Thread Starter
I thought anything 94 thru 98 was the same as far as parts go. However, I just went to the junk yard and their computer said won't cross reference to any of the years from a 96. Does anyone know if a front seat from anywhere between the above years will fit my 96? Thanks.
Sent from AutoGuide.com App
1996 F-250 7.3L Powerstroke extended cab. 255,000 miles and strong as ever.
"The nine most terrifying words in the English language are: 'I'm from the government and I'm here to help.'" - Ronald Regan
str8razor is offline
post #2 of 5 Old 04-26-2013, 11:29 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
92-97 f-150/250/350 extended cab and bronco front seats will all work for you, and in general all seats will mount to your existing seat tracks unless your going from a bench seat then you would need all the brackets
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 5 Old 04-26-2013, 11:48 AM Thread Starter
It do have a bench seat. Does this mean I will need to get another bench seat or get some kind of brackets if buckets are all I can find?
post #4 of 5 Old 04-26-2013, 01:26 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Any bench will bolt to your existing brackets, but if you want a 40/20/40, or buckets, you will need the brackets along with the seat and you have to drill a couple holes to keep it aligned
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 5 Old 04-26-2013, 03:37 PM Thread Starter
Thanks!
