Problem Replacing Shifter Boot - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-25-2013, 05:27 PM Thread Starter
b.mielenhausen's Avatar
I am trying to install a new shift boot on my truck because the plastic trim and inner boot are shot.
I ordered part (F5tz7277a) which is the black outer boot and white inner boot, but when i removed my old boot I found the inner boot was black and not attached to the outer cover.
I was able to remove the four screws on the black plastic trim and the two bolts on the shifter lever, but I am unsure how to remove the old rubber shift boot over the square shaped shifter end. I am not sure if I have the wrong part or how exactly I can get the old rubber outter shifter boot off and the new piece one.
Thanks for the help!
1996 F-350 Regular Cab 7.3L 4X4 ZF5 4.10
Mods: 6637 on K&N Tube, 3" Down / 4" Straight Exhaust, Beans 6 Pos. Chip, 285/75/16 AT's
b.mielenhausen is offline
post #2 of 2 Old 04-27-2013, 08:27 AM
Patrick Feeley's Avatar
Quoted: 8 Post(s)
That should be the right part. The new boot (both sections) should stretch enough to allow the shifter handle to slide through (you can always lube it a little with silicon spray). It wasn't all that bad when I did my 94's. I just put the boot assembly on the main shifter handle part and then attached that to the stub on the tranny and then screwed down the trim to the floor. Probably not that helpful, but ... Cheers!
Patrick Feeley is offline
