broke the fuel tank switch - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-25-2013, 10:51 AM Thread Starter
I tried to take the dash apart but couldnt get the headlight pull switch to come off is there some special trick or is destined to break too.
hithebrakes is offline
post #2 of 6 Old 04-25-2013, 10:56 AM
nohsp4u's Avatar
According to the ford manual, when you pull the switch out, there is a long gap, put a screw driver in there and push down on the tang while you pull the knob out. Of course it tells you to disco the neg first.
1997 F-350 XLT Lariat Crewcab long box 4x4. Oxford white with an ugly green. 133xxx miles. Hide away goose neck, banks turbo, exhaust, inner cooler, intake filter and gauges.
nohsp4u is offline
post #3 of 6 Old 04-25-2013, 11:12 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
use a small flat head, use it to lift the small clip in there and it will come rite off
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 6 Old 04-25-2013, 11:14 AM
nohsp4u's Avatar
Lift, push, crap I need to learn to read better, thanks 351
nohsp4u is offline
post #5 of 6 Old 04-25-2013, 11:18 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
no problem, I ripped a dash out in the JY before I realized there are screws behind the "trim strips" as well, they are 8mm iirc, don't break your dash too lol
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 6 Old 04-25-2013, 12:50 PM Thread Starter
OK thats what I thought I tried to remove that piece with a screwdriver and it started to break. Now I know I should order a new knob. Thanks for the help
