Later model seats for ext cab - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-23-2013, 07:39 PM Thread Starter
What seats work best for a f350 extended cab. More important, what doesn't work. Since I will need the seats to hinge for rear seat area entry.
97 F350 7.3 super cab full bed dually
Autometer Sport Comp II boost and egt
TS 6pos tuner
Clutch clevis mod
Tymar intake
Stancor/White & Rogers GPR
Dyno test 221.5hp @ 187,000 mi. Before mods.
Other mods soon :
diamond back dp and 4in exh
ebp del ped
ccv mod
ww2.
drsmith3 is offline
post #2 of 9 Old 04-27-2013, 04:57 PM Thread Starter
Is anyone there?
TS 6pos tuner
Clutch clevis mod
Tymar intake
Other mods soon :
ebp del ped
ccv mod
ww2.
drsmith3 is offline
post #3 of 9 Old 04-27-2013, 08:52 PM
sethc24's Avatar
I'd like too know this too as my 97 f250 ext cab is in need of new seating bad.
1997 F-250 4x4. 5 speed
, 6637,exhaust,dp-tuner,dana 60, 33's
sethc24 is offline
post #4 of 9 Old 04-27-2013, 09:02 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Super cab and bronco fronts are bolt in, anything else needs fabrication
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 9 Old 04-27-2013, 09:10 PM
leojr's Avatar
Quoted: 4 Post(s)
What I think I've learned is that Bronco and Ext Cab seats are unique to themselves and can be swapped amongst themselves.
All regular cab and crew cab seats are interchangeable as long as you move the seat pan with them, even front to back.
If I remember correctly, the Bronco and Ext cab seats can be put into a regular cab and a crew cab if the front/back adjuster tracks or the flop-forward track is removed from its seat base and bolted to the proper standard or crew cab seat base.
I believe I can move my front 40/20/40 seat to the rear of my crew cab when I find a either another 40/20/40 seat for the front or a great condition set of seats from a Bronco or Ext cab and will remove them from their seat bases and put them onto an extra 40/20/40 base I have purchased just for this upgrade.
I hope this helps.....
Denton, TX
I envy those that know exactly which modification to make and in the most logical of sequences. But not enough to trade for my meanderings and misfires.
1996 F250 crew cab/short bed, 4x4, auto PSD, 6637 air filter, interior grab handles, stainless window vents, remote door locks work with engine running mod.
leojr is offline
post #6 of 9 Old 04-28-2013, 06:05 AM Thread Starter
So........my takeaway from this.....I'm likely better off to reupholstery my bench seat since there are not any options for the extended cab?
TS 6pos tuner
Clutch clevis mod
Tymar intake
Other mods soon :
ebp del ped
ccv mod
ww2.
drsmith3 is offline
post #7 of 9 Old 04-28-2013, 10:10 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Swap in buckets and console or 40/20/40 from a super cab or bronco, and fabricate sd seats to fit
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 9 Old 04-28-2013, 10:39 AM Thread Starter
Thanks Kris
TS 6pos tuner
Clutch clevis mod
Tymar intake
Other mods soon :
ebp del ped
ccv mod
ww2.
drsmith3 is offline
post #9 of 9 Old 04-28-2013, 11:51 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
If your lucky you can find a super cab in the yard with power seats, very rare, but was not offered in any other cab configuration
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
