Fan won't switch from defrost to other settings - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-12-2013, 06:55 PM Thread Starter
Hey guys,
My interior fan won't switch from defrost to any of the other settings. Is this just an electrical issue? Any idea how to fix?
Thanks!
Raker80 is offline
post #2 of 8 Old 04-12-2013, 07:30 PM
Quoted: 4 Post(s)
Sounds like you have a vacuum leak.
F250419 is offline
post #3 of 8 Old 04-12-2013, 08:01 PM
Maverick1701's Avatar
Send a message via AIM to Maverick1701
^ this!
123456789
ChrisChris
2003 Kawasaki KLR650
1997 Ford Expedition 4x4
1967 Kaiser Jeep M35A2 6x6
2016 Silverado 4x4 Crew-Cab LS/Police
Maverick1701 is offline
post #4 of 8 Old 04-13-2013, 05:10 AM Thread Starter
Thanks. How do i fix this?
Raker80 is offline
post #5 of 8 Old 04-13-2013, 07:19 AM
Patrick Feeley's Avatar
Quoted: 17 Post(s)
Check the small white vacuum line in the engine compartment (it likes to rot out). Cheers!
Patrick Feeley is offline
post #6 of 8 Old 04-14-2013, 10:44 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
That small white tube is for ac/max ac, check your vacuum pump
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 8 Old 04-14-2013, 12:09 PM Thread Starter
Stupid question, but where is the vacuum pump and what does it look like?
Raker80 is offline
post #8 of 8 Old 04-14-2013, 01:04 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
its typically silver in color and just under a/c compressor, on the right side of the engine as your looking at it
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
