08 Buckets and console are installed - Ford Powerstroke Diesel Forum
post #1 of 24 Old 03-30-2013, 07:00 PM Thread Starter
Ranzan's Avatar
Quoted: 20 Post(s)
I got a chance to install my new set of seats today pretty straight forward install
I had to completely rewire the drivers seat harness due to the memory on them
I did not have time to run the new power harness to the seats as of yet that will have to be the next step of the project i ran out of time this weekend
Wes
2010 F350 CCLB 4x4 Lariat Sterling Grey
11 and up Console upgrade
2 1/2 levelling kit
1995 F350 CCLB XLT Stock for now....
1997 F350 CCLB 4x4 5 speed Tourmaline green
DDP Stage 1`s
08 Bucket console upgrade ( SOLD )
Ranzan is offline
post #2 of 24 Old 03-30-2013, 10:33 PM
toad's Avatar
Quoted: 16 Post(s)
Looks good. How do they fit?
1996 F250 crew cab. Hypermax intercooler, Gearhead tunes, 4" exhaust, 6637 intake, Autometer gauges, Dana 60, 6.0 cooling fan, Built e40d, Firestone airbags, Full Force stage ones more to come. SOLD
2003 7.3 F250 Lariat. Mostly stock.
toad is offline
post #3 of 24 Old 03-30-2013, 11:39 PM
BIG Laing's Avatar
Good work! Did you use photobucket? If you did, use the image code not the image thumb.
BIG Laing is offline
post #4 of 24 Old 03-30-2013, 11:56 PM
PowerstrokeSoldier's Avatar
This is awesome...I am looking to upgrade my vinyl bench seats in my 2004 to 08 or later buckets. Surely these did't bolt right in. What kind of fabrication did you have to do?
2004 F250 FX4, 6-speed manual, crew cab , SB, all stock!
PowerstrokeSoldier is offline
post #5 of 24 Old 03-31-2013, 12:52 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Looks good, kinda funny having memory power seats and crank windows tho lol, but you did a great job, I got to re attempt mine Kause the seats are not quite level and you can tell after about an hour, but first 20 minutes they are 10 times better
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 24 Old 03-31-2013, 01:15 AM
'086.4LDiEsEl''s Avatar
Quoted: 2 Post(s)
very nice, I think they look great in your truck!
'086.4LDiEsEl' is offline
post #7 of 24 Old 03-31-2013, 05:15 AM Thread Starter
Ranzan's Avatar
Quoted: 20 Post(s)
they are a tight fit..... I took my time inside the cab with the seats loose and powered them back and forth a few times
Having the stick there i wanted to make sure I could install everything without modifying the console mounts.
I`m 6`1 so I powered them back on the tracks as far as they would go then set them in out of reach of the pedals. I then powered them into a comfortable driving position
where i have them mounted just touches the belt retractors on the B pillars of the truck fully extended
powerstrokesoldier yours should be a direct bolt in unlike mine
351 mine are the same as yours the front outer mounts on both drivers and passenger are going to get aluminium spaces installed I took measurements before i tightened them down
I used 7/16 bolts with 1 1/4 washers on top and 1/14 washers and lock washers on the bottom side to make sure they were mounted securely
the only crappy thing about the seats was the memory on the drivers seat
you cannot get power to it with the drivers seat memory module
so I tore the drivers harness apart and copied the passenger harness
I depinnnd all the connectors and resodered and shrink tubed all the wires
I have never liked power windows really so no big deal for me lol
and I fixed the pictures lol I didn't look at the post after I submitted it
Wes
2 1/2 levelling kit
DDP Stage 1`s
Ranzan is offline
post #8 of 24 Old 03-31-2013, 05:20 AM Thread Starter
Ranzan's Avatar
Quoted: 20 Post(s)
I think this is the mocha or stone coloured seats they don't look really tan in the truck fortunately
Wes
2 1/2 levelling kit
DDP Stage 1`s
Ranzan is offline
post #9 of 24 Old 03-31-2013, 07:05 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
One day.... one day.... is the center console skinnier then a jump seat or the exact same measurement.? I prefer the jump seat but if the console make tthm fit better, so be it.
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #10 of 24 Old 03-31-2013, 08:03 AM Thread Starter
Ranzan's Avatar
Quoted: 20 Post(s)
Frank the console and jump seat are using the same mounting hardware so are interchangeable
Wes
2 1/2 levelling kit
DDP Stage 1`s
Ranzan is offline
