97 driver's door won't open from the inside. - Ford Powerstroke Diesel Forum
post #1 of 15 Old 01-28-2008, 05:48 PM Thread Starter
Started about two weeks ago. I'd have to pull the handle a couple times and it would open fine. Now it just won't open. Is there an adjustment on the cable?
Opens from the outside no problem.
JP Hallman is offline
post #2 of 15 Old 01-28-2008, 05:51 PM
rankroddin250's Avatar
on most obs trucks all the way up on the inside door handle is to far? try pulling it up all the way then letting it down a little bit... I usualy just push out on the door while im pulling the handle to find the G spot.
oh and to powerstroke.org
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
The People of a free country should not be scared of their government, the government should be scared of their people.
rankroddin250 is offline
post #3 of 15 Old 01-28-2008, 05:52 PM
broncrider's Avatar
ya take the panel off and youll see the opening lever adn youll see were the door handle is attached and then were the cable hooks. take a screw driver and open the gap up. kinda hard to explain but thats what i had to do to mine after i broke the door handle off
1996 F-250 dually convertion
intercooler
D.I.Y intake system
FPR shimmed
DIY exaust brake
dFuser 18k+
custom tunes by brians truck shop
3 inch down pipe/4 inch straigh pipe/6 inch
bullhaulers
SouthBend 350 Clutch
broncrider is offline
post #4 of 15 Old 01-28-2008, 07:13 PM
on mine the handle stuck and would not pull. all i had to do was pull the door panel off and clean/lube the pivot on the handle for it to work properly.
99 F350 CCLB 67k miles.
Sold: 01 Dodge cummins ECLB a few more mods to 353hp
Sold: 97 F250 SCLB, 5 speed 2wd. minor mods to 327hp
See a pattern? next I will have to find one of those 6 door jobbers...
Big Bird is offline
post #5 of 15 Old 01-28-2008, 07:33 PM Thread Starter
Thanks folks! I'll get on it! Broke the handle off mine too.
post #6 of 15 Old 01-30-2008, 04:02 PM
broncrider's Avatar
dont worry they break a lot. just know that cause auto zone carries them out on the display. thought that was kinda funny when i got mine
intercooler
D.I.Y intake system
FPR shimmed
DIY exaust brake
dFuser 18k+
bullhaulers
post #7 of 15 Old 01-30-2008, 05:09 PM Thread Starter
OK Lads! Ripped the panel off today, added a "spacer" to the end of the cable(the mount looks normal) The cable must be stretched. Then fashioned a piece of angle with a bit of heater hose on it for looks...door works better than new now. I just have to "look" at it the right way and the door opens on my command. Just like my women! Alright!
post #8 of 15 Old 01-30-2008, 05:11 PM Thread Starter
Have em' right out on display huh?...hmmm, Might get one if I have a hot date and want to impress...for now, mines a custom, one of a kind job.
post #9 of 15 Old 01-30-2008, 05:20 PM
broncrider's Avatar
ya i know how you feel. i went around for a while with the panel off with vise grips on the cable..and before that i just rolled down the window
intercooler
D.I.Y intake system
FPR shimmed
DIY exaust brake
dFuser 18k+
bullhaulers
post #10 of 15 Old 02-24-2008, 06:44 AM
Farmboy444's Avatar
Take the door skin off and shim the cable where it connects to the handle with a washer or nut and then put it all back together and it will work better than new, just look at it and itll open for you
2006 F-250 ExtCab SB 4x4 6.0, recon white lightning, ARP head studs, SCT touch Xtreme and soon to come Complete EGR delet y pipe and all
Wifes - 2005 Liberty w/ 2.8l diesel!
Daily Driver - 2006 VW Jetta TDI manual
Sold - 97 7.3 235k fun miles & 93 5.9 with only 84k
Farmboy444 is offline
