HELP: 2000 Ext Cab Seats in OBS - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-21-2013, 08:10 PM Thread Starter
gotsomegetsome's Avatar
I'm trying to swap 40 20 40 seats from a 2000 extended cab SD f250. I read everywhere that these were practically bolt on, but this is definitely not the case
I originally had the bench seat XL. If anyone has any suggestions, please send them my way. The floor does not match the brackets at all. Do I need to get OBS 40 20 40 seat brackets? Is there a bunch of modification that I need to do?
gotsomegetsome is offline
post #2 of 6 Old 04-04-2013, 08:29 PM
Fordtruck16's Avatar
Did u figure it out? I think I'm going to be in a similar situation when I do it
Fordtruck16 is offline
post #3 of 6 Old 04-04-2013, 08:32 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
You have to bend the sd seats "feet" to conform, and drill almost all new holes, I used crew cab seats in my crew cab though
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 6 Old 04-04-2013, 08:40 PM Thread Starter
I thought the bending idea was a bad idea and I did not want to drill any holes into the floorboards. So, I welded up some brackets based on the original bolt hole and stud arrangement. It comes down to 4 feet brackets with the rear feet reinforced to accommodate any force loads if you were to get into a wreck. I used the SD brackets, about cut in half, and welded to flat bars that span the width of the cab, which are then welded to the feet. Maybe more work than typical, but I could not find obs brackets anywhere at all..
post #5 of 6 Old 04-04-2013, 08:49 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Yeah I bent mine and used big bolts washers and nuts, bending repetitively weakens steal, but mine hold up just fine as is
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 6 Old 04-20-2013, 07:13 AM
KS_
Quoted: 22 Post(s)
I'd love to do this very thing to my obs, I cant stand the bucket seats anymore.. after 500k some miles its time for something new
  • Kaleb - 97 F-250. 1.0 housing, WW2, 3 inch dp to 3.5 straight pipe, TS 6POS chip, Riffraff 6637 Intake, 4" Rough Country Suspension Lift and 33"s.
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
KS_ is offline
