Double Din? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-19-2013, 05:11 AM Thread Starter
PSD_rookie's Avatar
Garage
Double Din?
I've seen 1 or 2 double din radios. I do automotive electronic installation for a living, primarily stereo equipment. I know there is/was a thread on here where a guy did it, but all the pics are gone "Sorry. This person moved or deleted this image" is all I can see. I've done custom fiberglass paneling, some leather wrap, etc. I'm just curious how much was done to the back of the dash, I haven't had a lot of time to look at mine, but I figured I can always get a second dash and modify it to just swap out. Also please don't try telling me to just go with a flip out/up screen, I've worked on radios for a long time and been doing it as a living for 2 years. I know what options I have for factory fit radios.
TOTALED - 95 F250 XLT ECLB 4x4
4" turbo back, DIY tymar, Boost/EGT/Trans temp Gauges, 35/12.5 tires, ZF-5 swap with solid driveshaft, Oh yea, and P-pumped 12 valve swap
97 F350 CCLB 4x4
PSD_rookie is offline
post #2 of 11 Old 03-19-2013, 07:23 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Sorry can't find piks, but I'm doing the same in my truck too, my plan is to go down to just above the hvac controls instead of up tho cheers and don't forget piks when you start to hack it up
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 11 Old 03-19-2013, 06:52 PM Thread Starter
PSD_rookie's Avatar
Garage
Yea, going up would be a bit more difficult and space limited due to the dash pade and limited space without fiberglassing the whole top. I planned on cutting down just a slight bit as you said, just above the HVAC. I'm going to have to figure out a way to make it easy to replicate so that I can possibly make a kit for people to make their own, or maybe even start doing them for people. None the less, pics will be very abundant when I do get it started.
97 F350 CCLB 4x4
post #4 of 11 Old 03-19-2013, 07:15 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Same here, gotta print diagrams and the like to figure it out lol
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 11 Old 03-20-2013, 07:15 AM
Martinique78's Avatar
Here is my install
I used a cracked dash pad since it was getting covered with fiberglass. I cut a piece of ABS plastic and hot glued it to the opening on the dash pad for the radio. I then removed the two screw tabs on the heater control trim. Matched the ABS plastic to the HVAC trim ring and epoxied it. I then laid the fiberglass on the pad, ABS and trim ring. I cut the hole for the double din radio, sanded the piece smooth and covered it with a gray vinyl. Then on the dash you need to cut out the section of the dash between the ration opening and the HVAC opening just big enough to fit the radio between it. In some cases you heed to heat up the air vent and push it is so the radio sits correctly. mount the radio in the dash then attache the pad, ABS and trim ring assembly as one piece.
92 F350 CCLB 4x4 W/96 PSD 7.3L E4OD
EBPV Delete, 120V IDM Mod, 3" Down Pipe
Van Turbo, OBD2 Electronics
Martinique78 is offline
post #6 of 11 Old 03-20-2013, 07:41 AM
superduty4x4's Avatar
Originally Posted by Martinique78 View Post
Here is my install
Can you get a few more pics of your setup- from the passenger side and a good view of what the dash looks like behind the radio would be great. Your install looks clean enough I'm considering doing this in mine!
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #7 of 11 Old 03-20-2013, 09:04 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
That looks much better than what I was originally planning, great install, any piks of the process
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 11 Old 03-20-2013, 09:14 AM
I will try and find my install pics but i'm afraid that they were lost due to a hard dive crash. If I get a chance to pull the radio I will do a write-up for everyone. I plan to recover the dash pad and radio bezel soon as the vinyl I used to cover it was to thick and didn't come out as smooth as I liked.
post #9 of 11 Old 03-21-2013, 09:00 PM
Looks quite good, impressed. How long to do that?
fasteddy88 is offline
post #10 of 11 Old 03-22-2013, 05:55 AM
Double Din?
Took about a week to do. I had a spare dash that I did the mock up on so I knew exactly what I needed to do on my dash in the truck so I didn't ruin it. Plus the way I did it I could always put it back to stock by installing the one piece I cut out and putting the original dash pad back on.
Sent from AutoGuide.com App
