Lightning seats...and gauges - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-09-2013, 02:30 PM Thread Starter
southchitownstrokin's Avatar
Looking at buying a set of 1st gen lightning seats, but wondering if I can keep the bench seat if I just put the buckets on the bench frames? I'm not a fan of the buckets with the center console. Anyone done this?
Also how hard is it to calibrate the speedo if I buy a 1st gen lightning gauge cluster?
southchitownstrokin is offline
post #2 of 10 Old 03-09-2013, 04:40 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
What seat do you have now? A bench?
If so, you need to unbolt the bench(4 bolts) and remove it from the truck.
THEN, you can put the lightning buckets in. They get bolted to a seat pan, then the whole pan gets bolted into the truck.
The lightning cluster will only work if you go by the correct year
92-93
94-95
96-97(if you have a 96 or 97 you are SOL, lightnings were only made till 95)
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #3 of 10 Old 03-09-2013, 04:59 PM Thread Starter
I have a 95, someone was saying since the speedo on the lightning gauges reads to 100 you had to recalibrate it... But your saying if the cluster is from a 95 truck it will just plug in and be correct?
And what I mean by the seats... I have a bench now. Was wondering if I can modify it to have the lightning buckets but keep the center part of the bench in the truck.
post #4 of 10 Old 03-09-2013, 06:05 PM
Quoted: 54 Post(s)
Um, if the "center part" is a separate part, it's not a bench.
madpogue is offline
post #5 of 10 Old 03-09-2013, 07:45 PM Thread Starter
Mine is.. It's a bench with the fold down center... And there is a gap between the drivers seat, center part, and pass seat...
post #6 of 10 Old 03-09-2013, 07:51 PM
Quoted: 54 Post(s)
You have a 40/20/40 seat. A bench seat is one piece. So the challenge is, do the Lightning buckets mount on the bracket/pan for the 40/20/40?
madpogue is offline
post #7 of 10 Old 03-09-2013, 07:57 PM Thread Starter
Ah my bad.. Thanks for clearing that up. Yeah just curious to see if anyone has done it.. I think it would be kinda cool to do. If I can't find anyone ill still attempt it myself
post #8 of 10 Old 03-09-2013, 08:50 PM
Maverick1701's Avatar
Send a message via AIM to Maverick1701
Somewhere around here (either here or FTE) someone built/made an OBS CC lightning with seats and everything. I tried to search but couldn't find it.
ChrisChris
2003 Kawasaki KLR650
1997 Ford Expedition 4x4
1967 Kaiser Jeep M35A2 6x6
2016 Silverado 4x4 Crew-Cab LS/Police
Maverick1701 is offline
post #9 of 10 Old 03-10-2013, 06:08 AM
Quoted: 4 Post(s)
YES, you can use the lightning seats(40-20-40) in place of your 40-20-40 seats, but will look like complete crap unless you get your 20 covered in the same charcoal material that the lightning seats are
post #10 of 10 Old 03-10-2013, 06:08 AM
Quoted: 4 Post(s)
And if the cluster came from a 95 and you have a 95 then the speedometer will be fine. The tach is another story
