All new wires. - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-07-2013, 06:38 PM Thread Starter
FeelDatPowerstroke's Avatar
All new wires.
Ive got a 94 PSD and the wiring through the entire truck is jacked up, i need a full wiring harnnes or something if they even make them for the truck anymore. They have messed the wires up so bad like for example you turn the lights on with the truck off the radio comes on. Also another thing is if your dash lights are dim the radio cuts off. one more thing is when its hooked up to a trailer if the lights are on and you try to use the blinkers they dont work right. like they will both flash and it will be off key. If anybody knows how i can solve the problems or knows of a good place to get a wiring harness please let me know.
FeelDatPowerstroke is offline
post #2 of 3 Old 03-07-2013, 07:23 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
Don't know where you might get a harness (or two), but I would suggest getting the Electrical and Vacuum Troubleshooting Manual (EVTM) from Helm Inc. Cheers!
Patrick Feeley is offline
post #3 of 3 Old 03-09-2013, 04:43 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
I would 1st start with removing EVERYTHING aftermarket and see what the truck does then
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
