'97 dash lights - Ford Powerstroke Diesel Forum
post #1 of 15 Old 01-01-2008, 04:40 PM Thread Starter
97bluestroker's Avatar
Send a message via AIM to 97bluestroker
'97 dash lights
i want to change my dash lighting from the stock green to blue... anyone done this before? suggestions? are there kits you can buy instead of changing out individual bulbs?
'97 F250 HD PSD, 4x4, Auto, Ext Cab, LB, 4" Lift, Tint, 80/120 hp DP Tuner, Straight Piped, AFE Stage 2 Air Intake w/ Pro-Guard 7, Aftermarket Intercooler, SpecRite Dual Disk Torque Converter, Pumped Up Tranny w/ Transgo Kit, MagHytec Deep Tranny Pan, Pyro, Boost and Tranny Temp Autometer Gauges, Pro Comp Adjustable Shocks, 305/70/16 BFG Mud Terrains on Weld Rims, Spray on Bedliner, Flip Down DVD Player
97bluestroker is offline
post #2 of 15 Old 01-01-2008, 04:47 PM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 2 Post(s)
the bulbs arent green in the factory dash, the bulbs are all white , the gauges themselves have the green transparent cover in them that gives them the color , there companies out there that sell aftermarket gauge covers , search the internet , may take some time to pin down what ypou want
ITS STOCK
SCUFFY828 is offline
post #3 of 15 Old 01-01-2008, 04:57 PM Thread Starter
Thanks... i was told before that i would need to change the bulbs to blue in order to change the color... if i can just change the cover that would be much more simple...
post #4 of 15 Old 01-01-2008, 05:02 PM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 2 Post(s)
well they do make bulb covers , or blue bulbs , but it probably wont be the color your looking for
ITS STOCK
post #5 of 15 Old 01-01-2008, 05:04 PM
KVFD
redstroker_2002's Avatar
ya you need to get a diff. gauge assembly if u are goin to do it
-Josh
2008 2500 LMM- Deleted, Blocked, Fueled, & Tuned by:
redstroker_2002 is offline
post #6 of 15 Old 01-01-2008, 05:05 PM Thread Starter
ya... i changed my pod gauges' bulbs and it was somewhat difficult, and the color isn't as intense as i want.. i'm going to eventually buy the autometer C2 gauges. i want the dash to match.. LOL
post #7 of 15 Old 01-01-2008, 05:11 PM Thread Starter
anyone know where i can find that cover? or even what to call it when i look online?
post #8 of 15 Old 01-01-2008, 05:14 PM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 2 Post(s)
its called the gauge faces
ITS STOCK
post #9 of 15 Old 01-02-2008, 04:00 AM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
I have never looked for a set for our trucks. I know you can get 'em for the SD's. Most you will find have white faces and you can pick what color you want. Some even have the ability to change the color with a switch. I'm just not sure what you will find for the OBS. Try Stillen. STILLEN : Precision Performance Components for Your Car or Truck
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #10 of 15 Old 01-02-2008, 07:37 AM
Ebay has the gauge faces,For our trucks look under gauges type in gauge face.
1997 F250 XLT CC PSD 4X4 4.10LS E4OD (AB CODE TRUCK)
DFUSER 18K MOD
4" TURBO BACK DI EXHAUST
1705 SUPERCHIP
DIY INTAKE
2" LEVELING
GAUGES,EGT,TRANS,BOOST,OIL TEMP,OIL PRES,WATER,VOLT
SONNAX VALVE/TRICUMULATER SPRINGS
30,000lb TRANS COOLER:
SWAMPS IDM
1996 F250 XLT EC PSD 4X4 4.10LS E4OD
1705 SUPERCHIP
DIY INTAKE
DB EXHAUST BRAKE
30,000LB TRANS COOLER
QUAD POD WITH EGT,TRANS,BOOST,WATER
140V IDM
ono_55 is offline
