cracked door panel - Ford Powerstroke Diesel Forum
post #1 of 8 Old 12-27-2007, 11:22 AM Thread Starter
bucwheat's Avatar
cracked door panel
confused:Got a problem w/a door panel,I have 286,000 miles on my 97 F-350 the interior is in great shape except for the door panel where my elbow rests, it has worn thin enough to crack and I can't find anything to glue it back together,tried Gorilla glue,epoxie,plastic w/hardener nothing stick to the plastic.Any suggestions?
bucwheat is offline
post #2 of 8 Old 12-28-2007, 07:15 PM
nicklekid's Avatar
Maybe try Testors Plastic Cement? Please post if you have any success.
My 96 interior door panels have not cracked, but feel weak. I have been considering replacement and would intertain an aftermarket replacement if available and more durable than the original.
nicklekid is offline
post #3 of 8 Old 12-28-2007, 07:17 PM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
You may try removing it and reinforcing the back side with fiberglass mat and resin.
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #4 of 8 Old 12-28-2007, 07:23 PM
duct tape & zip ties
bigcountrysg's Avatar
Go to junk yards, search the web. You just need to find one that is the same color as yours. Any door panel from 95-98 should work.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #5 of 8 Old 12-29-2007, 07:33 AM Thread Starter
bucwheat's Avatar
Well I figured some type of repair would be less trouble and cheaper than a total replacement,Don't have many good boneyards around here.
bucwheat is offline
post #6 of 8 Old 12-29-2007, 10:12 AM
MacDougall's Avatar
I had a problem like that were the plastic on the door panel cracked but i used gorilla glue and it worked just fine, stuck great. when you used the gorilla glue did you add a little bit of water to the glue before putting it on and did you clean the area will well ? if you did both those I'm not sure why the gorilla glue didn't work.
Mike:
2003 F250 CCSB 4X4, 6.0L powerstroke.
-Sinister coolant filter
-Upgraded blue spring
-5" diamond eye exhaust W/ 6" tip
-Edge CS
-SCT tuner W/ vivians looney tune
MacDougall is offline
post #7 of 8 Old 12-30-2007, 07:47 AM Thread Starter
bucwheat's Avatar
I may try it again,may not have put enough water on it.
bucwheat is offline
post #8 of 8 Old 12-30-2007, 03:35 PM
CSXPAID's Avatar
plastic welder from harbor frieght about $30.00 comes with abs plastic welding rods
CSXPAID is offline
