Turn Signals - Ford Powerstroke Diesel Forum
Old 02-13-2013, 07:54 AM
Turn Signals
My turn signals are out on my 97. Emergency flashers work. All bulbs are good. All fuses are good. Any suggestions?
Old 02-13-2013, 07:58 AM
7.3 4 Ever! Nothing else!
Feedback Score: 7 reviews
Multi fuction switch aka blinker switch
Old 02-13-2013, 03:15 PM
Or the flasher. There are two separate flashers, one for the emergencies and one for the directionals. One's on the other side of the fuse box, the side you can't see. I forget which is which (it's in the owner's manual), but you could just swap them and see if that makes the directionals work and the emergencies fail.
Old 02-13-2013, 03:58 PM
The flasher on the front of the fuse panel is for the blinkers
Old 02-13-2013, 04:26 PM
I bought a new multi switch and the problem still persisted. So I know its not that. I now have them working intermittently. I will check out the flashers and see what I can see.
Old 02-14-2013, 06:46 PM
It was the flasher. Never knew...but then again this is my first 200.000 mile truck.
