Electronic door lock wont work. - Ford Powerstroke Diesel Forum
Old 02-03-2013, 08:08 PM
Well, my locks won't work by pressing either of the door lock buttons, and the switch is getting power. What could it be?
Old 02-04-2013, 02:21 PM
Broken wires, bad actuators ,....
Old 02-04-2013, 06:05 PM
If it was wiring, I wouldn't have power to the switch, any other possibilities? I want to rule out as much as possible.
Old 02-05-2013, 05:17 AM
UM.... do you think it is wireless to the lock actuator from the switch? They need power too
Old 02-05-2013, 05:29 AM
It is not on a key fab. It is the switch on the door.
Old 02-05-2013, 01:05 PM
wiring 101
Power comes from the battery
to
the fuse panel
THEN
to the door lock switch
when you push the door lock switch
power goes to the door
lock actuator
All this happens THRU WIRES
Old 02-05-2013, 06:36 PM
Well its not wireless, goes from actuator to switch through wires, I'm sayig if there was a short, i wouldn't have power to the switch which i have.
Old 02-06-2013, 01:42 AM
And what about a BROKEN wire?
Tags
door, electronic, lock, power, switch
