Rear door lock actuator bracket removal - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-03-2013, 10:48 AM Thread Starter
alpinhi's Avatar
I got to work last week on real cold morning. When I locked the doors I heard a snap and something fell down inside the rear driver side door. Turns out the bracket that the door actuator sits on broke. I think the actuator is still good, I just need to replace the bracket. I cant figure out how to get it out though. I can turn the metal round threaded part on the outside of the door but I cant get a screw driver to grab on the inside. Any ideas would be great.
Thanks
Travis
96 F250 Crewcab shortbed 4x4
Tymar intake, Warn hubs, B&W Gooseneck and fifth wheel hitch, 285/75/16 Michelin A/T2's
09 Unlimited Jeep Rubicon
2" lift, 315/70/17 BFG At's, Warn 9000lb winch.
Trying to afford modifying 2 vehicles is tough!
IAFF Local 1596
alpinhi is offline
post #2 of 4 Old 02-03-2013, 01:28 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
On mine, it was a large rivet that I had to drill out. I used a stainless 1/4" screw/nut combo on reinstall. Cheers!
Patrick Feeley is offline
post #3 of 4 Old 02-03-2013, 02:06 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
It is a LARGE steel 1/4" rivet. You need to either drill or grind it off.
If that "bracket" broke. Good luck getting another one
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #4 of 4 Old 02-03-2013, 02:09 PM Thread Starter
alpinhi's Avatar
Perfect! Thats my kinda fix!
The search for a "new" one will begin. I may look at trying build one also. Thanks for the help.
Travis
IAFF Local 1596
alpinhi is offline
