Dome and courtesy light problem. - Ford Powerstroke Diesel Forum
post #1 of 10 Old 01-22-2013, 06:38 PM Thread Starter
jwatkins's Avatar
First off, my dome and courtesy light used to stay on when the key was off and the doors were open, then after ten minutes of so the would shut off automatically.Now they will not turn on until you start it and shut the door then they will turn on but as soon as you shut it off they go out.
Iíve checked all of the fuses with a test light and all of them are good. Iíve tried replacing the door chime box but that was a no go. Is there a control moduel just for that or something.
B] 97 ford f-350 Powerstroke[/B]
d-60, 02' zf-6 tranny, 6637,FPR Shim, Custom Dual 5" Exhaust and 3" dp, TS six position, Devils Own water/meth, DIY Exhaust brake, Pro-tech headache rack with Peterson LEDs, home made front and rear bumper, DIY leveling kit, SD steering column pod, Isspro EGT and Boost, Home made OHC.
jwatkins is offline
post #2 of 10 Old 01-22-2013, 08:15 PM
Quoted: 44 Post(s)
What year truck?
madpogue is offline
post #3 of 10 Old 01-22-2013, 10:33 PM Thread Starter
jwatkins's Avatar
Re: Dome and courtesy light problem.
It is a 97.
jwatkins is offline
post #4 of 10 Old 01-23-2013, 05:13 AM
mkeith54's Avatar
I'd suspect the RKE module, though there maybe a way to program the times. Might check the manual.
Mike Keith
New Florence Mo
1996 F-250 ECSB, 6-pos/ts chip/ Tymar intake
Pyro, boost, and tranny gauges
mkeith54 is offline
post #5 of 10 Old 01-23-2013, 07:55 AM Thread Starter
jwatkins's Avatar
I've been through the owners manual several times and I can't find anything. What is the RKE module?
Also forgot to add that the map lights can turn on when ever you want. The bulb for the dome light I brand new.
jwatkins is offline
post #6 of 10 Old 01-23-2013, 09:46 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Rke is remote keyless entry
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 10 Old 01-23-2013, 01:19 PM
mkeith54's Avatar
^^What he said.^^
Map lights should be able to be turned on at any time manually. I'm not sure that the module on these trucks are programmable. However, the only thing in the wiring diagrams that controls the illuminated entry and battery save features that I see is the remote keyless entry. According to the diagrams it is located above the accelerator pedal on a bracket, as my truck does not have RKE I can't tell you what it looks like. Maybe someone else will chime in.
Mike Keith
New Florence Mo
mkeith54 is offline
post #8 of 10 Old 01-23-2013, 04:16 PM Thread Starter
jwatkins's Avatar
Thanks I found the modual today it appears to be ok. I can feel it click when I push on the door sensor so I guess my problem is somewhere else.
jwatkins is offline
post #9 of 10 Old 01-24-2013, 10:06 PM
Electrical Ogre
alberta 7.3's Avatar
Quoted: 114 Post(s)
Just because you hear relays clicking in the module doesn't mean it's good.
Hit a wrecker and grab one from a 93-95 Ford/Lincoln/Mercury, just look for a car with a door keypad. The module will either be in the trunk (Taurus/Sable) or under the dash (Lincoln)
Bill
1996 F250 SC/SB 4X4 XLT
1997 F250 RC/SB 2WD project
2008 F350 CC/LB 4X4 DRW Lariat, 3" cow catcher mod
2008 Ranger SC FX4
Originally Posted by weareweird69 View Post
If your posting pictures bill, everyone dim their screens, that CAT YELLOW is bright
Originally Posted by Fordman247365 View Post
Is there anything you DONT take apart and **** with?
Originally Posted by JJFLASH View Post
I still say that those Dodge mirrors have as much business on a OBS Ford as yoga pants have on a fat chick...my .02
alberta 7.3 is offline
post #10 of 10 Old 01-25-2013, 08:11 AM Thread Starter
jwatkins's Avatar
Ok. Thanks for the info. I'm starting to get a pretty long junk yard list, since the nearest one is 60 miles.
jwatkins is offline
