12 volt electric power ports not working.
I have a 1995 Ford F350 dually crew cab centurion conversion 7.3 liter powerstroke.
Just purchased it a few days ago. Ok, due to age, it has a few issues. But for starters.... The center console which contains some accent lights and the old analog TV have no power. I found the console plugs into a 12 volt power port located on the floor just under the righ side of the driver bucket seat. My question is....anyone have any idea where it gets power from, fuse location. This I believe is not a ford add on but a centurion add on. Thanks. Photo is a view at floor level from the back seat. Last edited by Warrennc; 10-28-2012 at 10:45 AM. Reason: Add photo |
WOW!?! I'm praying that it runs all the way back to the batteries as that center console sounds like it could eat a lot of power.
It could draw a lot of power if it worked. Just trying to locate the wiring so I can fix it, find the fuse and test/replace it to get it working again.
Figured I would fix it before changing things. Maybe install a small flat screen that runs off 12 volts or just forget it and convert the TV box to storage. Will check the battery connections or at least the high amp connections for extra circuits/fuses and see if I can find where they go. I know of at least 3. One for the aux driving lights and two others I do not know where they go....yet. May just pull fuses to see what fails. Their fuses tested good. Thanks BigFuel. Last edited by Warrennc; 10-29-2012 at 05:20 PM. |
No worries, call me Matt.
| Tags |
| 12 volt power port, center console, centurion |
