In Need of a under dash wire diagram
looking to change my manual doors to power, want to see if the connectors under the dash will work for the power windows
They should be the same harness in the trucks with or without the power windows. I can try to link up a wiring diagram when I get a chance if you still need it.
Sorry but my wiring diagram program is protected and I cannot upload it. Grab a Haynes or Chiltons manual and try their wiring diagram if you really need it.
you may be able to tell me this, is the harness for the power windows and power doors a separate harness... i was trying to follow the harness going to the door and it led up to under the glove box did this at a junk yard didnt have a lot of time to look for it bc i had to get back to work (went on break)
if it is a separate harness that would be awesome i looked in my xl and i couldn't find the connectors for it
The harness from the door in mine connects to the main harness behind the kickpanel and that harness runs up behind the dash. The harness may be tucked away somewhere behind the kick panel. I checked the passenger side I would assume the driver side is the same. I may be able to snap a pic this weekend if I get time.
That would be great, I know they connect at the kick panel but i followed after that and it went up towards the glove box and from what I could tell across.. idk this is bout to make me mad n give up wish I had a parts truck or place for one and rip apart
Sent from my C771 using AutoGuide.Com Free App |
The dash side of the harness was in the metal part of the kickpanel. I think it is the one you are describing, but I will try to get in a little deeper with some pics of the connectors.
Thanks
The wiring for the window motors and locks is part of the cab harness, not the dash harness. Ford LOVES to screw around with wiring and wire connectors though, so proceed with caution... it may not be plug and play. If your truck has keyless entry, you will need a donor harness from a truck with keyless entry, that much I'm sure of.
