dash lamps - Ford Powerstroke Diesel Forum
Old 05-27-2012, 07:01 PM
dash lamps
what lamps are in the insturment cluster?
wanting led lamps.
Old 05-28-2012, 05:41 PM
well they are 194 in case any one wants to know.
Old 05-30-2012, 04:47 PM
lol, make sure you use superbright ones, just regular ones leave dark spots, i know from experience, and it was just to much of a pita to swap again since i didnt need to pull my dash no more lol
Old 06-01-2012, 02:52 PM
How in the F do you get the head light switch off to pull the rest of the dash out?
Old 06-01-2012, 03:13 PM
The knob has a release style spring which locks on the switch stem
Pull switch and release the knob .
Old 06-01-2012, 03:49 PM
Ya the spring locks into a groove on the shaft if I remember right. I used a small stiff wire and bent a U in it and that did the trick for me. Good luck
Old 06-01-2012, 05:24 PM
Thanks guys, gonna give this a shot tonight. Anybody know off hand how many bulbs total are in the instrument cluster?
Old 06-04-2012, 05:15 PM
superbrightleds.com
WLED-WHP5
Look great and don't give you "hot spots". Get enough to do the HVAC panel.
Old 06-14-2012, 04:03 PM
De-rail in 3... 2... 1...
Also, don't forget to test your set-up before reassembly. LED's are diodes and only work in one direction.
