97 Ford F250 Brake Controller
I bought a 97 F250 about a year ago and am slowly fixing it up to be my every day or every other day driver. The problem I am working on right now is the brake controller. When I bought it the controller was just on the ground with no mount in the truck anywhere. Also, the guy wired it up by just twisting wires together. I've had a couple of sparks from when I turn the corner, the controller slides, and the wires touch with some sparks. I am thinking it is about time to fix this. Does anyone know where I can get a mounting harness? What do you recommend for connecting the wires? These are the two numbers I got off of the box. Thanks for the help.
R2217-001REVB F81B-14K122-BA |
You definitely need to fix that. First thing, disconnect the batteries so you don't short anything out. Next trace the power wire and see if it has a fuse/breaker. You need to use a auto resetting slow blow. Next take one wire at a time, slide some heat shrink over one end and solder the two ends together. If you don't have a soldering gun/iron, use some crimp connectors.
If you dont have a mounting brkt then you can do what i did, i put mine in the lower cubby slot in the dazh just to the right of the steering wheel below the ignition. Drill a hole big enough for the wires to go through and slide it in, it wedges right in there and have never had an issue with it moving.
